Help with cummins isl9 280
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by joet247, Dec 12, 2019.
  1. joet247
    joet247 Bobtail Member
    hi, i'm working on a cummins isl9 and i keep getting a red stop engine light on. the code is 0555 which is Crankcase Pressure – Data Valid but Above Normal Operational Range – Moderately Severe Level, i have replaced the crank case filter, the crankcase filter box, the crankcase pressure sensor, oil drain tubes, check valves, breather tubes,oil separator plugged. still reading 24.5 inH2O when accelerating. any ideas please help thanks
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Did you check the wiring out yet??
    pushbroom Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    You most likely indeed have excessive crankcase pressure assuming your sensor is rational 0.0inhg KOEO. Next steps would include isolating the turbocharger and air compressor one at a time to note a decrease in pressure during operation. From there with no change its teardown time or run cylinder leakage test to check rings.
  5. joet247
    Thank you. iv been trying to tell my boss that the motor most likely will need to be torn down. i am thinking it will be the rings or the sleeves. but i work for the city so they would rather me throw everything else at it before i tear it down... haha but i appreciate the fast reply!
  6. Raffito
    Raffito Light Load Member
    84
    53
    Aug 25, 2019
    Ingram, TX
    I'm Second Goodysnap! Had same issue on ISL9, change crankcase filter and still had code for crankcase pressure. Perform compression test and cylinder # 5 and 6 were bad..
