help with double clutching
Discussion in 'Questions From New Drivers' started by SevereTireDamage, Jan 27, 2015.
  1. SevereTireDamage
    SevereTireDamage Bobtail Member
    Texas
    I'm driving a 2007 kenworth t600 with a 13 speed. Can someone give me a detailed step by step on how to double clutch like a pro.
    Much appreciated, thanks
  3. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    Ok here goes
    1. Remember it is all in the feet not the hands
    2. When you get ready to shift right foot should be coming up as the left foot is going down slap shift in neutral then left foot should be coming up as right foot goes down then it is right foot coming up left foot going down slap in gear left foot coming up right foot going down
    3. It takes awhile to get the hang of it but you will
    SevereTireDamage Thanks this.
  4. 77smartin
    77smartin Road Train Member
    2,183
    3,024
    Apr 3, 2011
    I dunno.
    Watch some youtube videos.
  5. Naptown
    Naptown Road Train Member
    1,156
    2,983
    Oct 18, 2009
    Indiana
    Don't press the clutch all the way to the floor. Just past the break point will do. Your clutch brake will thank you, unless someone else has already tore it up for you.
  6. Trckdrvr
    Trckdrvr Heavy Load Member
    742
    621
    Dec 25, 2010
    Georgia
    its simple..
    Double clutching is No more than treating neutral as a gear..
    first gear
    clutch
    neutral
    clutch
    second gear
    clutch
    neutral
    clutch
    third gear
    clutch
    neutral
    clutch
    fourth gear
    etc
    etc
  7. flybynight12
    flybynight12 Medium Load Member
    683
    539
    Jan 10, 2015
    slc
    first gear float second gear float third gear etc etc etc
  8. ineedajob
    ineedajob Light Load Member
    232
    191
    Oct 18, 2014
    Just barely depress the clutch. Pull out. Release. Barely depress the clutch put into gear release. Each truck has a sweet spot but generally hit about 1500 rpm then when it drops to about 11 or 1200 you should be in the next gear as far as timing. (In my experience)
  9. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    People are saying barely press the clutch,let's brake that down to an inch.As long as you're not one of those grind them till you find them type of drivers you'll be alright.In due time you'll be able to double clutch like a pro.
    Lepton1 Thanks this.
  10. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Also remember you don't need to push the clutch to the floor just around 1/4 or so. It becomes like clock work.. I learned to float gears first then I thought my self how to double clutch by just messing arund with it.
  11. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,442
    Jun 9, 2010
    Home
    OK! Here the best explanation on how to double clutch like a pro............. Are you ready................ Now :biggrin_255:FLOAT
