HELP
Discussion in 'Ask An Owner Operator' started by jander, Apr 4, 2014.
  1. jander
    jander Bobtail Member
    Aug 15, 2010
    39
    Thanks Received:
    miami FL
    i think ur right...it has a 9 speed converted to a 13 speed
  2. hydraliccruiser
    hydraliccruiser Bobtail Member
    Apr 4, 2014
    21
    Thanks Received:
    8
    Keep in mind cat stoped supportn boyscouts last year
  3. jander
    Aug 15, 2010
    39
    Thanks Received:
    miami FL
    yeah and the also stoped series 60 12.7
  4. Ukumfe
    Ukumfe Medium Load Member
    Oct 23, 2008
    301
    Thanks Received:
    515
    Post number 1 you say a 9 speed. Post number 11 is now a 13 speed, or to be accurate the 9 speed converted to a 13. you do the conversion from post 2-10?
    Cetane+ Thanks this.
  5. jander
    Aug 15, 2010
    39
    Thanks Received:
    miami FL
    yeah it got converted jajajajaja... nahh i forgot to mention it, since its not an original 13 spd!!
  6. kw550cat
    kw550cat Medium Load Member
    May 22, 2012
    663
    Thanks Received:
    596
    brooklyn, new york
    Swap or convert the nine speed for a thirteen speed. Keep the 3.70s they will pay off in the hills. The cat will not get you that much more if any mpg but it will make you go faster and get up hills easier.
  7. jander
    Aug 15, 2010
    39
    Thanks Received:
    miami FL
    thing i was looking to get both worlds..lower my rpms for a lil better fuel milage and power when i need it...i dont do alot of hill if any hills..i run miami fl to jersey,pa and back, but now im runing 1550 at 66 to 67 and im doing 5.4mpg.i would like to get 5.8 or 6.0
  8. sixthgear11
    sixthgear11 Light Load Member
    Sep 24, 2011
    197
    Thanks Received:
    192
    myrtle beach, sc
    Keep in mind, you've stretched it, and you're now dragging a sail in the wind with all the air that's slipping between the truck and trailer... If you've gotten it back up to 5.5, I don't think you're gonna get much better no matter what you do..
  9. jander
    Aug 15, 2010
    39
    Thanks Received:
    miami FL
    before i raised the hp to 575 with a new program to the ecm i was getting like 6.2 same set up, but it was weak
  10. hydraliccruiser
    Apr 4, 2014
    21
    Thanks Received:
    8
    There was a tennis ball under pedal or brake was not released...
    Lmsf
