High pressure in coolant system???
Discussion in 'Volvo Forum' started by bizzzzzz1, Oct 4, 2014.
  1. bizzzzzz1
    bizzzzzz1 Light Load Member
    66
    27
    Jan 1, 2013
    Hello everybody,
    Got a problem, today i noticed i have the secondary reservoir full and the main one empty. When i tried to take the cap out lots of air was leaking from the reservoir. Now no antifreeze leakage around the head. Oil was clean.
    I know usually the problem in such cases is a bad head or head gasket. What else can cause this?
    Thank you!
    2007 volvo d12, 660k miles
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    How hot has it been running?
  4. Flightline
    Flightline Road Train Member
    2,345
    1,167
    Oct 1, 2011
    Almost There
    Are you getting bubbles or just pressure build up?
    Do you have a heat control valve under the bunk that is air operated?
    I've had injector cups leak exhaust into the coolant.
    Is the coolant reservoir tank inside getting any darker?
    If you think it's exhaust or compression from the engine, the parts stores sell a test kit for the antifreeze for determining this.
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    the 07 volvo d12 is bad about egr coolers leaking and in some cases pressurizing coolant system, another possibility on the d12 is a air compressor with a bad head gasket will do this as well. napa sells a combustion gas tester, not very expensive ( like flightline mentioned). there is also a water indicating paste you can put on your dipstick and insert it down in the oil and wait a min or two and pull it out and it will tell you if there is any coolant in the oil.... when this trk sits overnight and you first start it do you get a puff of white smoke followed by a sweet smell of burning coolant?. just some suggestions from someone who has been in that situation. first and last swedish junker i will ever buy. sold that 07 volvo a year after i bought it.
  6. bizzzzzz1
    66
    27
    Jan 1, 2013
    Flightline, i don't know about the bunk air valve, will check that on monday.
    Tank is not getting darker.
  7. bizzzzzz1
    66
    27
    Jan 1, 2013
    It never ran too hot. Fan always comes on in time so it was cooling it down like its suppose.
  8. bizzzzzz1
    66
    27
    Jan 1, 2013
    No white smoke at all, will go monday to see if i can find any kind of tests that you guys are saying. Let you know what i found.
  9. v6killer
    v6killer Medium Load Member
    448
    122
    Dec 6, 2010
    ChicagoLand
    I have Herd that the expansion tank that sits on top of the radiator, gose bad sometimes, Check On the driver side of the expansion tank, there is a blue cap It's supposed to release the pressure, if it doesn't, It tends to push the coolant out, instead of the air pressure.
    mjax1 Thanks this.
  10. bizzzzzz1
    66
    27
    Jan 1, 2013
    Checked the air that makes the pressure in the coolant system, it is not combustion gas, which is a good thing :), changed the blue cap from the coolant reservoir and still doing the same. Now i guess the air compressor goes bad, so i will change that tomorrow and hopefully problem will be solved.
  11. Cat sdp
    Cat sdp . .
    21,298
    76,142
    Apr 8, 2012
    Orion's Belt
    Isolate the air compressor and see if that helps (block the intake ).... That will tell you if your on the right track .
