High temp regen runs indefinitely: help!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by AFS tech, Aug 7, 2019.
  1. AFS tech
    AFS tech Bobtail Member
    6
    Aug 7, 2019
    im working on a 2010 WS 4700 with a DD13 engine.
    Came in DPF was 84% clogged had it cleaned the other active DTC was intake mani pressure sensor replaced that as well. Now all active codes are gone except the infamous 3719. Which in theory all you would have to do isn’t send it through regen and bam done. Not in this case it will run for hours and never go above 813 degrees. Doser valve should kick on around 900?? If I remember correctly. I have tested the following and all are good.
    Turbo
    Jake brakes(in spec)
    Egr valve works on command through DDL
    And I monitored it seems to be fine. Closes to 85% during regen
    ITV works
    Doser valve and block(new)
    Fuel filters (new)
    Air and baro are within .5psi
    I can’t figure this out
  3. AFS tech
    6
    Aug 7, 2019
    Update: doc inlet and doc outlet temps are around the same and both peak out at or around 800 degrees and stays at that temp
  4. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    What’s your DOC inlet pressure?anything above 1.5 psi, your Doc or inlet PSI sensor is plugged.
    If your psi sensor is cleared and your temps still don’t come up, you’ll need to pull the DPF’s back out and Blow or out the DOC’s. Remove the 1-box inlet and rig a good vacuum cleaner to or all that soot will settle in front of the DOC and plug at least part of them again!
    If your pressures are good, look back toward your HC Doser or EGR systems to find the issue there.
  5. Dave_in_AZ
    424,079
    How many miles?
    Cat sdp Thanks this.
  6. AFS tech
    6
    Aug 7, 2019
    I tested the EGR and the egr is operating correctly I also monitored it during regen it’s 85% closed.
    As far as pressure if I remember the inlet was 0.034 outlet was 0.00
  7. AFS tech
    6
    Aug 7, 2019
    350k
    Dave_in_AZ Thanks this.
  8. AFS tech
    6
    Aug 7, 2019
    Blew out the DOCs during regen I have DPF inlet- 0.363
    DPF outlet- 0.072
    DOC inlet temp-813
    DOC outlet temp-779
    Fuel doser-0.0%
    Fuel cutoff valve- 0.0%
    Baro-14.43
    Intake mani - 14.71
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Plugged DOC or drifted DOC outlet temp sensor.
    AModelCat Thanks this.
  10. AFS tech
    6
    Aug 7, 2019
    I replaced temp sensors and I’m getting same response I’m currently doing a DOC face plug cleaning hoping it fixes it if not I’m quite sure it’s gonna need a new box
    spsauerland Thanks this.
  11. Cat sdp
    Cat sdp . .
    21,300
    76,159
    Apr 8, 2012
    Orion's Belt
    5lb hammer to the dpf should cure it......
