Hitch ball
Discussion in 'Ask An Owner Operator' started by zinita17601, Jun 26, 2019.
  1. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Im doing a project around the house and need to move some dirt and rocks,i dont have a pick up truck and wanting to keep my cost to a minimum.
    Local companies rent a 6000 lbs dump trailer for $90 a day which is perfect for what im doing.
    Im thinking of installing a hitch ball on my tractor to pull this trailer and maybe a small boat trailer in the future. What else do i need to be legal and where do i get the parts?thank you
  3. ETMF 58 White
    ETMF 58 White Light Load Member
    90
    219
    Jan 4, 2019
    Electric brake controller unless the rental dump trailer has surge brakes. Four-way flat light plug or RV plug, whichever is on the dump trailer. Maybe some sort of rings to hook the safety chains. Be careful jacking around on non-paved surfaces filling your drive tires full of rocks, then bobtailing, so to speak, with your little dump trailer. You’ll be buying a new mirror. Or, if you’re really unlucky like I was once, you can throw a rock over the cab and then run into it with your windshield.
    stwik, Ruthless and zinita17601 Thank this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Rent a truck from Home Depot. Likely your least expensive option.
    The ones around here do have the 7 way w/ a break controller.
  5. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Im aware of that option i can
    Im aware of that option $175 a day,i can also rent a dump truck for $250 from sunbelt,i just wanna work on my own schedule and dont have to worry about a time frame
  6. Ridgeline
    22,717
    123,134
    Go to any good welder or trailer shop, done this a bunch of times. The brakes are the one thing to worry about, I went to an air over electric controller for the rv truck.
  7. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    You won't need the trailer brakes for 6000 lbs, that's less than a trailer.
