Hopper tire wear problems ?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by markk, Nov 24, 2022.
  1. markk
    markk Medium Load Member
    566
    197
    Nov 14, 2011
    Thought I would share this info.
    Is your Timpte or Wilson hopper 2018 and up eating up tires 3 times a year ?
    Inner and outer edges wearing off fast like low inflation problem.
    It is not air or the tire. It is them flimsy Hendrickson axles. They flex.
    At almost 5k for a set of Chinese tires, 3 times a year is a bunch of cash.
    Cure : have them aligned. Then weld thick angle iron on top and bottom of axle . No more flexing .
    Will be doing mine if I ever manage to make money again.
  3. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    The angle iron trick worked for mine
    markk Thanks this.
  4. W923
    W923 Road Train Member
    1,419
    4,387
    Feb 28, 2022
    If the axles flexing are the actual problem why isn’t only the inside of the tires wearing. I can’t think of a scenario where an axle flexing would cause the outside edge to wear. Maybe the Chinese tires are the problem…i have had very mixed results with them in general some last and wear well others wear funny or maybe even but only last 50k miles.
    Welding angle iron to the axles sounds like a great way to make dot look harder at your rig. Just a thought
    NightWind and markk Thank this.
  5. markk
    566
    197
    Nov 14, 2011
    As I was told by a guy with plenty of hoppers , it is because of them axles.
    He has his trailers aligned and balance bags put in and it does nothing. 3 sets a year.
    My 2021 timpte had Bridgstones on it and they did not last long. I thought it was the inflation system not working correctly. I removed it. Kept tires aired up and the edges wore off and ruined them . Inner tread just fine.
    Now I have some Chinese tires on. They have deep tread. Put steers on drop axle [ front axle ]. We will see how long they last.
  6. markk
    566
    197
    Nov 14, 2011
    Seems like a good thing. Tires are pricey these days. I get tires at cost. Them iron man etc about 6 months ago were about 175 bucks for drives . Now they are more like 350.
    I paid 2150 for 4 Chinese trailer tires in Texas a couple , months ago.
    My guy here put 4 steers on front trailer axle plus 2 drives on truck for 2600. Not too bad.
  7. markk
    566
    197
    Nov 14, 2011
    I have no idea how it eats up outside edge. But they all seem to do it. You would think it might get the outside edge of maybe the inside tire. But it eats em up like low air pressure.
    I'm wondering if perhaps it is because if they are flexing then while driving along the bumps in road might be causing them to flex up and down. That would probably account for both edges .
  8. NightWind
    NightWind Road Train Member
    2,718
    19,173
    Nov 11, 2006
    Sunny South, AL
    Have you had the bushings replaced? That's the main problem that I've seen over the years. If the bushings are worn out then no amount of alignment is going to work. Welding ANYTHING in place that isn't supposed to be welding is asking for more problems IMHO
    Last Call, wis bang and W923 Thank this.
  9. markk
    566
    197
    Nov 14, 2011
    No. It's a 2021. Shouldn't have any bad bushings. It just wears em out. Has to be warping. Otherwise could not eat up inside and outside edges . It would only eat one or the other .
  10. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    Some people bend the axles a little extra to compensate for the flex. Then when loaded, the axle is straight. A tanker company in Carrol IA pre bends all the new trailer axles.
    markk Thanks this.
  11. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    I know I'am not compairing apples to apples but that Wilson has had problems with the axle tearing away from the subframe on their spead axle livestock trailers that started in the 2018 models also
    Wilson doesn't want to own up to the issue.. but sure is funny that they claim they redesigned the subframe in mid 2020 models
    markk and NightWind Thank this.
