Horsepower question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hedon, Mar 1, 2010.
  1. Hedon
    Hedon Light Load Member
    121
    95
    Jun 29, 2009
    SW Missouri
    Every thing else being equal, what would you prefer for engine setting?
    It's a Detroit 14L and can be set at:
    515 # 1800 RPMS
    490 # 1800 RPMS
    455 # 1800 RPMS
    455/515 # 1800 RPMS
    What are the benefits and downsides of setting it at 515 as far as fuel mileage goes? What about engine wear?
    Obviously I know the 515 gives me more power and I admit that's attractive but I'm also trying to be all grown-up and consider fuel mileage. Sigh.
  3. crop jocky
    crop jocky Light Load Member
    140
    95
    Dec 29, 2009
    You should turn it up, the motor works less thus for you get better fuel mileage driven moderately, We currently are running the mercedes motors and before they cut them back we were getting almost 7mpg. They cut horsepower from 445 to 400 and cut rpm from 2100 to 1650 and we are down to 5.5mpg. It sucks we are lugging them all the time, cut them from 70mph to 64mph. these are company trucks and its for insurance reasons. It really sucks the trucks have started burning more oil aswell.
    Hedon Thanks this.
  4. Mr. PlumCrazy
    Mr. PlumCrazy Road Train Member
    1,341
    606
    Jul 30, 2009
    Lexington NC
    455 wont get much better fuel mileage than 515 depending on your driving what helps the most in fuel mileage is transmission and rear gears matching for best fuel economy depending on where you run. The lowest I would go on rear gears is 3.42 anything much lower will eat your fuel millage up if you have a lot of hills to climb. Highest I would go is 3.58 and some would say as high as 3.70 but any thing higher will eat your fuel mileage up if you run a lot of flat land
    RoughHouse and Hedon Thank this.
  5. Gonzo_
    Gonzo_ Medium Load Member
    307
    143
    Oct 30, 2008
    Clayton, NC
    The best fuel milage tool you have is that RIGHT FOOT not the HP setting... Using common sense will go a lot further than the hair splitting.. I say just set it at the max.. (If your tranny and rears are rated for the torque) and just feather the fuel peddle w/ that right foot, you don't need to drive "flat footed" all the time.. use that head, and some good old fashioned common sense..
    Hedon Thanks this.
  6. rollin coal
    rollin coal Road Train Member
    13,603
    27,966
    Mar 29, 2008
    TN
    I hate to be a nitpicker but 3:70 is the "lowest" ratio with 3:42 being the "highest" it's the opposite of what one would normally think. I have 3:70's in my truck and love that gear set in the hills and mountains on interstates like I-81. It's also great on flatlands as long as you keep the rpms down. My truck runs 67 mph at 1500 rpms with 11r22.5's just right. At 72mph I turn 1600rpms.
  7. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    i'm pretty sure 3:70 isn't the lowest, i've seen 3:90's before, they pull great in the sand.
    Hedon Thanks this.
  8. Hedon
    121
    95
    Jun 29, 2009
    SW Missouri
    Thanks guys. In the end we decided to leave it set at 515... now if I can just keep my right foot out of it all should be well. :biggrin_25523:
  9. sweezly1
    sweezly1 Medium Load Member
    361
    267
    Mar 24, 2008
    ohio
    keep us posted on how you are making out. we have made a few adjustments to ours and have not found that magic number yet. still not very good fuel mileage.
  10. Hedon
    121
    95
    Jun 29, 2009
    SW Missouri
    Will do. It's weird we were driving it home last night (bobtail) and I could swear it was getting better fuel mileage at 72 than it was at 63 or 65.
    I don't know... maybe it was just wishful thinking on my part. I do like me a fast truck.:biggrin_25524:
  11. sweezly1
    361
    267
    Mar 24, 2008
    ohio
    we had ours turned down to 68 mph and were getting awlful fuel mileage , then we turned it up and are getting better now. its weird for sure.
