HOS calculation
Discussion in 'Questions From New Drivers' started by Bigtruckdrver504, Dec 29, 2021.
  1. Bigtruckdrver504
    Bigtruckdrver504 Bobtail Member
    28
    17
    Dec 12, 2021
    New Orleans
    I have read the HOS article and sort of confused..
    I read the 34 hour reset part,the 11 hr day max, and no more than 60 hours in 7 days thing/ or 70 hrs in 8 days...
    So does it mean I can legally work 25 hrs total for Sat & Sunday?
    Since I work 35 hrs at my existing job. 60-35= 25
    If I have an existing job(Non-cdl) working 35 hrs a week(Mon-Fri), how many hours could I legally drive on weekends?
  3. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    1st, it would be 70 hours in 8 days if you are working weekend, as the carrier is working all 7 days.
    Let's expand this out to explain.
    Day 1: 7
    Day 2: +7 = 14
    Day 3: +7 =21
    Day 4: +7 =28
    Day 5: +7 =35
    Day 6: +12 = 47 (just making up a number, it could be anything from 1 minute to 24 hours.)
    Day 7: +12 = 59
    Day 8: +7 = 66
    Day 9: +7, -7 = 66 (The -7 is last Monday falling off)
    Day 10: +7, -7 = 66
    Day 11:: +7, -7 = 66
    Day 12: : +7, -7 = 66
    Day 13 +11, -7 (Saturday.) = 70 (you would run out of hours before the 12 hour shift is over, assuming a 12 hour shift.
    Day 14: Have to take a reset, as there is no time available.
    Reason for edit: Fixed my math
    meechyaboy and Accidental Trucker Thank this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,571
    9,929
    Mar 30, 2014
    60 hour 7 days and 70 hours 8 days are 2 different regulations. If 1 applies, the other doesn't. In the vast majority of operations, 70/8 will apply. If your company does not run 7 days a week, then the 60/7 rule applies.
    So in your case, you would be able to drive 35 hours, less your on duty time. The next weekend you probably wouldn't be able to do that much
  5. meechyaboy
    meechyaboy Heavy Load Member
    796
    1,227
    Oct 4, 2018
    Detroit, Michigan
    Would you even be able to drive if there’s never a reset? The working our would be fine as you could technically work what he’d want.. but I don’t think it would work for drive time
  6. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Yes one can. Let's use my numbers from above, but assume a "normal" 8 hour work day on the weekend...
    Days 1-5: = 35
    Day 6: +8 = 43
    Day 7: +8 = 51
    Day 8: +7 = 58
    Day 9-12: +7, -7 = 58
    Day 13 +8 , -7 = 59
    Day 14: +8, -8 = 59
    Day 15: +7, -8 = 58
    etc....
    P.S. I missed the Saturday of -7 hours, so I edited the above post.
    meechyaboy Thanks this.
  7. Bigtruckdrver504
    28
    17
    Dec 12, 2021
    New Orleans
    Ok so the first Saturday & Sunday , I can work 12 hrs each day, and the next weekend Saturday I can work 11 hrs and take off that Sunday? Correct?
  8. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    That's how the math works. Real life the numbers won't be exact, but I hope you get the idea.
  9. Bigtruckdrver504
    28
    17
    Dec 12, 2021
    New Orleans
    Yea I do as if the first Sat I only work 8 instead of 12.. I can use the other 4 hrs somewhere else?
  10. REALITY098765
    REALITY098765 Road Train Member
    1,520
    1,350
    Sep 17, 2017
    If you do the 35 in 4 days ,say mon to thursday and reset on Fri, then you would have up to 70 hrs available to work on the weekend.
  11. Bigtruckdrver504
    28
    17
    Dec 12, 2021
    New Orleans
    Thanks.I get that, we normally work Mon - Friday - 7hrs per day each total 35 hrs.
    Maybe I'll look into dump truck work with the spare time I have.. I just was trying to understand how these hours will work
