HOS question
Discussion in 'Canadian Truckers Forum' started by HighwaySuperTramp, Dec 14, 2018.
  1. HighwaySuperTramp
    HighwaySuperTramp Medium Load Member
    316
    349
    Feb 8, 2015
    Now this sounds stupid, but I know just about every other rule aside from the Canadian split sleeper. I even understand and use the US split sleeper when I needed it when I ran reefer.
    I don't really need the Split sleeper rule to use it since my runs are fairly reasonable, I just want to know how it works, and please avoid using regulatory jargon. That's half the issue most people dont understand the laws. Lol
    So crayon and color paper me.
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Well, if you use and understand the US split-break rules, then you can use the Canadian split-break rules. They are very similar, but the Canadian rules are more flexible.
    Canadian split-break:
    • two blocks of time
    • both blocks must be sleeper berth
    • the two blocks together must add up to 10 hours
    • the lesser of the two blocks cannot be less than 2 hours, other than that, they can be any combination adding up to 10; so, 3.5 + 6.5, 7.75 + 2.25, etc.
    • adding up the on-duty periods both before and after each of the blocks of time spent in the sleeper berth, you cannot exceed your 13, 14 or 16 hour clocks
    • any on-duty time, off-duty not in the sleeper, or non-qualifying sleeper time (eg. less than 2 hours) counts towards the 16 hour clock
    • cannot be used in conjunction with the Deferral rule
    The rules are actually reasonably straightforward.
    I have found this document to be very helpful too.
    The only other thing to keep in mind is that your daily limits on your 13, 14 and 16 still apply and you must have at least 10 hours off-duty/sleeper berth in a day.
  4. HighwaySuperTramp
    316
    349
    Feb 8, 2015
    Reading it like this, it made perfect sense. I could never make sense of it out of the book, and I've met no one who could explain it anything like this. It was some arbitrary and complicated thing. Thank you so much
    magoo68, BigHossVolvo and not4hire Thank this.
  5. EddieK
    EddieK Bobtail Member
    13
    Jan 20, 2014
    Regina, SK
    “both blocks must be sleeper berth”
    That’s actually incorrect. The 2-hour block can just as well be recorded off-duty as long as you spent the time resting.
  6. tinytim
    tinytim Road Train Member
    5,145
    19,039
    Oct 29, 2007
    Northern Ontario
    I think you're talking about the US rules.
    magoo68 and not4hire Thank this.
  7. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    Canadian rules required both of the split-break periods in the sleeper.
    Splitting of Daily Off-duty Time — Single Driver
    • 18 (1) A driver who is driving a commercial vehicle fitted with a sleeper berth may meet the mandatory off-duty time and daily off-duty time requirements of sections 13 and 14 by accumulating off-duty time in no more than 2 periods if
      • (a) neither period of off-duty time is shorter than 2 hours;
      • (b) the total of the 2 periods of off-duty time is at least 10 hours;
      • (c) the off-duty time is spent resting in the sleeper berth;
      • (d) the total of the driving time in the periods immediately before and after each of the periods of off-duty time does not exceed 13 hours;
      • (e) the elapsed time in the periods immediately before and after each of the periods of off-duty time does not include any driving time after the 16th hour after the driver comes on-duty;
      • (f) none of the daily off-duty time is deferred to the next day; and
      • (g) the total of the on-duty time in the periods immediately before and after each of the periods of off-duty time referred to in paragraph (b) does not include any driving time after the 14th hour.
  8. tinytim
    5,145
    19,039
    Oct 29, 2007
    Northern Ontario
    As far as Canadian rules go 8 off duty gives you a fresh work shift, no splitting required.
  9. EddieK
    13
    Jan 20, 2014
    Regina, SK
    You’re own link proves you wrong bud.
    There’s no requirement for drivers to record time spent in the sleeper as sleeper berth it can
  10. EddieK
    13
    Jan 20, 2014
    Regina, SK
    There’s no requirement for drivers to record time spent in the sleeper as sleeper berth it can be just as well recorded off-duty
  11. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    :rolleyes:
    How are you going to comply with 18(1)(c) if it isn't recorded as sleeper berth time?
    Officer: I notice you recorded 6 hours sleeper berth and your second period of 4 hours as off-duty, but you're trying to claim a split-break. Where was second period of 4 hours spent?
    EddieK: In the sleeper.
    Officer: But that isn't what your logs say, and under the split-break rule, both periods must be in the sleeper.
    EddieK: Yeah, I was resting in the sleeper.
    Officer: Well, that isn't what your logs say. You can park it over there to take your 10 out-of-service.​
    magoo68, Phantom Trucker and tinytim Thank this.
