Hos question
Discussion in 'Questions From New Drivers' started by trexidente, Dec 6, 2022.
  1. trexidente
    trexidente Bobtail Member
    0700 drop off - 1630 pickup - 0130 dropoff
    It's an 18.5 hour window with no time for a 7hr sleeper berth. My question is, how can this be done legally?
  3. zaroba
    zaroba Heavy Load Member
    840
    1,269
    Aug 28, 2012
    South East PA
    Dropoff to pickup is 9.5 hours. Unless you need to do over 2.5 hours of driving between the two it should be enough for 7 hours of sleeper. Theoretically if everything works perfectly and the split gives you the hours needed to deliver.
    If not, I'd tell my dispatcher it was impossible to make the pickup on time and/or impossible to deliver on time due to hours. They might still have you do the load, but they can't (or shouldn't) hold you accountable if you communicate the issue.
    tscottme Thanks this.
  4. Concorde
    Concorde Road Train Member
    5,428
    19,090
    Jun 29, 2016
    West Melbourne Florida
    Impossible to answer your question without estimated travel times.
    Bean Jr., Boondock and tscottme Thank this.
  5. Ridgeline
    22,709
    122,574
    Don't think so.
  6. trexidente
    drop to pick 1hr. pick to drop 3 hr. reefer live load/unloads.
  7. SmoothBore
    SmoothBore Medium Load Member
    451
    709
    Jun 8, 2011
    The Desert
    Depends, do you have e-logs?
  8. Cattleman84
    Cattleman84 Road Train Member
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    So you are saying that you cant unload, drive 1 hr, load, then drive 3 hours to arrive for second unload drop in 18 hours????
    4 hours of drive time in total... Even if the first 2 places take 7 hours each to unload/load you should be golden.
    Easy peasy... Check in at reciever, go to sleeper berth, drive 1 hr, check in at shipper, go to sleeper berth, once loaded creep to a parking place out of the way at shipper to finish split berth, drive to reciever.
    D.Tibbitt and Boondock Thank this.
  9. Concorde
    5,428
    19,090
    Jun 29, 2016
    You would need a miracle to pull it off. Your first drop you’d need 7hrs uninterrupted SB then the rest would work.
    The miracle would be that the receiver took 7 hours to unload once you bumped the dock..or they had a staging lot you could creep to without tripping your log.
    Today I drove from South Atlanta to somewhere Kentucky in the rain and fog to deliver..Then a 2 hour drive to Walton, Ky where I’m at now still waiting to be loaded. I’m going on my 18th hour of my shift.. and I’m still 100% legal.
    Once I’m loaded I will creep about 150 feet and finish my 10. Few hours pillow time and I’ll be rolling to York, PA for a delivery tomorrow night.
    Not really the way I like to run but it was 100% doable because I knew I could get my 10 completed at my pick.
    If you haven’t been to your first stop yet read the reviews on the place and see what everyone is saying. Usually someone will say something in regards parking.
    Boondock Thanks this.
  10. trexidente
    Was 2 hours unloading and 1 hour drive smh
    Also I was coming off an 8 hr sb arrived at first stop with 1.5hr duty remaining
  11. Moosetek13
    Moosetek13 Road Train Member
    14,938
    18,939
    Nov 1, 2010
    Burnsville, MN
    My questions would not be if it could be done legally.
    One would be, why would I work those crazy hours?
    Another would be, where would I find parking after that delivery after that long of a day - at that time of night?
    And what if you do pull it off?
    What will your company expect for your next loads? More splits with 8 hours off and getting back on the road until you kill yourself (possibly others on the road) with fatigue?
    Do yourself a favor.
    Control your time.
    Learn to say NO!
    MSWS, tscottme, Numb and 1 other person Thank this.
