Hot Wire
Discussion in 'CB Radio Forum' started by 12 ga, Nov 19, 2013.
  1. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Can someone advise the best ( easiest ) way to run a hot wire from a battery into the cab for a kicker on a KW W900.
    Thank you in advance.
  3. muleshoe
    muleshoe Light Load Member
    67
    28
    Jul 4, 2013
    Is there a pre- existing opening anywhere on the cab or sleeper? If so I would try to use that. If not you' ll probably have to drill a hole for your hot wire.
  4. Bashnya
    Bashnya Light Load Member
    103
    100
    Jan 2, 2012
    Kingman, Arizona
    Try to keep the run as short as possible. Some guys like to snake it up under the cab and through the hole for the shifter. Never been a big fan of that because it's too easy for the wire to get pinched. If you have to drill a hole make sure you run the wire through a rubber grommet so it doesn't rub against the metal of the cab. Doing this will also keep the weather out.
    Don't forget to fuse it! I always like to run dual fuses, one at the battery and another up by the radio/amp. Overkill? Maybe, but better safe than sorry.
  5. wore out
    wore out Numbered Classic
    17,178
    212,088
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Well if fused at both ends it insures the kicker and radio are protected. I do it that way to I use a lower amp fuse (manufacturers recomendation) on the radio side and a 30 amp on battery side. That way should wire get chaffed the 30 will kill power so the wire doesn't melt and the smaller fuse protected the radio. Fuses are cheap.
  6. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Thanks for the information, all good ideas, I think I will put them together for best results.
