Hot wire?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckerPete1990, Feb 15, 2017.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    So I got a 07 9400i. I'm trying to tap into my work lights to run new ones... problem is they won't power my leds. Is there away to make that wire produce more power without melting them lol
    On my muiltmeter it's only doing about .12....
  3. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Do you need to ground them?
  4. AModelCat
    163,624
    Short answer: No, a wire will melt if you try and draw too many amps through it.
    LED's are polarity sensitive. Did you hook them up properly?
  5. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    I have it grounded to a bolt outside. If i take the wire i ran from my LED light and touch to the Battery it works but taping into the old Wiring that already has a switch it won't power the led. Im trying to avoid having to run another wire & Switch
  6. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    yeah im sure its grounded out on a bolt that has a Really good ground. If i touch hot wire to the battery powers right up. But soon as i hook into old wire it won't power it. Im still getting .11 from my muiltmeter at the top where the new work lights just wont power em. Didn't think LED would need more power then what its getting lol
  7. AModelCat
    163,624
    So are you just splicing into the power wire to the existing lights? Are the old lights working?
  8. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Correct Yes the old ones work fine. They power up.. Its what got me stumbled lol
  9. AModelCat
    163,624
    Yeah that makes no sense unless you've got the leads on the LED's reversed or you have a poor ground on the lights. I would advise making sure the wiring and components in the circuit you are tapping into are capable of handling the increased amperage.
    rabbiporkchop Thanks this.
  10. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Sounds like the ground that you're trying to use isn't a good one. Try running a temporary ground wire back to the battery from the LED lights and see if they come on. If so, that's your issue.
    edit: Just read the post where you said they work if you run a positive straight to the battery.
    In that case, you have a bad connection somewhere in your original circuit. You're going to have to physically trace the wire back and check for corroded splices or connections.
  11. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    But at the Top where they wire spices into led im getting the same .11 - .12 there same as where the original spice in it is. Im thinking that the wire just can't handle it.
