How is this possible??
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rolls canardly, Apr 21, 2025.
  1. rolls canardly
    rolls canardly Road Train Member
    1,629
    4,076
    Feb 7, 2009
    mt. pocono. pa.
    On my 2007 Freightliner M-2 106 I just spent $ 1000 on New tie rod,
    both new ends, New USA drums and shoes, and front end alignment.
    Drag Link is a year old with no visible slop when moved.
    Alignment shop checked king pins/bushing and they are tight.
    I even took a 6' bar and tried to move {anything} that could cause shimmy.
    At 65, it shakes like a dog shi*ting razor blades.
    After that, 68 to 75 - it's smooth as glass.
    I was always told a shake at any speed is a tire balance issue.
    I got 2 new front tires mounted and balanced for another 600 bucks.
    I watched the guy make it perfect zeros on digital readout and in balance.
    So i'm into this for over $1500 and it shakes like it needs a drink.
    Any Ideas?
    broke down plumber Thanks this.
  3. bad-luck
    bad-luck Road Train Member
    3,426
    6,310
    Nov 16, 2013
    Baltimore, Maryland
    Where is the shake? Is it in the steering wheel or the whole truck? Could be rear tires
  4. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,356
    Nov 1, 2017
    The Sticks, Idaho
    Bad alignment would be my first guess.
  5. JB7
    JB7 Road Train Member
    1,001
    1,769
    Dec 13, 2022
    Laurel, MD
    Front end shakes and bouncing?? | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board
    See posts 9,11,26 but read them all.
  6. AModelCat
    164,279
    Not an apples to apples comparison but I had a failed u-joint on a pickup years ago. It would shudder, shake and bounce like crazy at around 68 to 75 km/h. Above or below that speed there was no shake.
  7. DUNE-T
    DUNE-T Road Train Member
    7,039
    17,145
    May 10, 2015
    Detroit, MI
    Was it shaking before you started repairs?
  8. Big Road Skateboard
    7,048
    39,915
    May 2, 2021
    Does it shake bobtail? If it's not in the steering wheel, drive tires would be one of my first things to look at
  9. Arctic_fox
    4,496
    25,350
    Sep 16, 2016
    Could be shocks too. My pete would bounce wildly 0-60 and smooth out 60-75
  10. Goodysnap
    Goodysnap Road Train Member
    3,769
    9,190
    Jul 12, 2017
    You need to backtrack and find out when this all started. Something has changed……when did it start?
    I would start with checking for runout and out of round on the steers. Any wear on the hub pilot/ wheel mounting?
    Bean Jr., wore out, Long FLD and 2 others Thank this.
  11. rolls canardly
    1,629
    4,076
    Feb 7, 2009
    mt. pocono. pa.
    Tomorrow I'm pulling both front wheel hubs and replacing all brgs.
    nothing else left.
    I have a hunch the inner bearing curbside is somewhat spalling.
    it's not yet rumbly, but it has a tone I noticed.
    Bean Jr. and singlescrewshaker Thank this.
