how many tarps do I need?
Discussion in 'Flatbed Trucking Forum' started by DietCoke1013, Sep 27, 2018.
  1. DietCoke1013
    DietCoke1013 Light Load Member
    69
    14
    Sep 11, 2018
    CHICAGO ILLINOIS
    Do I need one 8 foot drop tarp and two 4 foot drop tarps? Who makes the best tarps?
    Also how many chains do you recommend?
  3. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,651
    Oct 5, 2012
    Earth
    Completely depends on what type of loads you're doing. 8 ft drops for lumber and everything else is fine, just more work. I've got 8s and 5s to cover everything, but managed just fine when I only had room for 8s. Even on flat on the deck loads. For that you'd need 8s with grommets at the very top as some done have that.
  4. DietCoke1013
    69
    14
    Sep 11, 2018
    CHICAGO ILLINOIS
    So I assume one 8 foot drop and a pair of 5s? I'm just running off the load board until I can find a shipper.
  5. Tb0n3
    4,738
    9,651
    Oct 5, 2012
    Earth
    Two of each of the if you plan on taking lumber or any taller items, 8s alone if you want to save money while not cutting out any loads, and you don't mind the work.
    Woodys Thanks this.
  6. DietCoke1013
    69
    14
    Sep 11, 2018
    CHICAGO ILLINOIS
    Two 8 foot drops then? Which tarp company do you prefer to buy from? Bungee tarp straps, I was thinking about 50 21 inch and 50 9 inch. Your thoughts?
  7. Ruthless
    Ruthless Road Train Member
    9,168
    91,039
    Aug 28, 2010
    The City.
    More bungees. Easy to use 50 @ 21” on a single tarp.
  8. DietCoke1013
    69
    14
    Sep 11, 2018
    CHICAGO ILLINOIS
    24 x 18 foot with 8 foot drop - heavy duty. You think two of these are good with 100 21 in bungee straps?
  9. stwik
    168,070
    Bungees are cheap insurance. Buy 100, minimum. Buy an extra box and keep in the truck with you.
    RERM, SAR, fargonaz and 2 others Thank this.
  10. Tb0n3
    4,738
    9,651
    Oct 5, 2012
    Earth
    Use your brain. Is your trailer 36 feet long? You should have enough to cover your entire trailer length plus some overlap, and you'll want a tongue piece to cover the end. Look up lumber tarps. Typically 24x26+8x8 flap.
    PoleCrusher and Ruthless Thank this.
  11. cke
    cke Road Train Member
    6,144
    75,622
    Aug 4, 2013
    Colfax Wi
    Minimum 150 21 inch bungees
    snowman_w900, SAR, fargonaz and 2 others Thank this.
