How much does my trailer empty weigh
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Hillbilly1987, May 6, 2018.
  1. Hillbilly1987
    Hillbilly1987 Bobtail Member
    8
    Feb 11, 2018
    this is my 3rd week into tanker stuff pulling a 2012 heil 9200 3 compartment trailer. Just wondering the weight
  3. hagarcobra
    hagarcobra Medium Load Member
    334
    747
    May 24, 2013
    Easy. Scale your tractor and trailer. Deduct weight of tractor.
    Frank Speak and tscottme Thank this.
  4. Hillbilly1987
    8
    Feb 11, 2018
    They don't have any scales on the yard and I have a short 75 mile haul with no scales anywhere
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Call your state police. Ask for someone to show up with portable scales as a training exercise to see what you are empty.
    Conversely google public scales near your exact location.
    Put everything on the platform it will come up with a number empty tractor and trailer. Pay the man his 10 dollars or whatever.
    Also...
    Your vehicle's data stamp on the inside of your tractor should have a tare and gross vehicle weight. Same thing with your trailer, whatever it is near the glad hands. Add em up.
    Somewhere on that Heil trailer should state capacity in either liters, pounds or US or imperial gallon. Find out the intended cargo, get a calculator out and start figuring what it will take to get you to 80000 pounds with such a payload capacity. Subtract and the result should roughly be your tare weight.
    Or call the trailer factory direct and ask very specifically about your specific trailer, HOW MUCH EMPTY IS IT as BUILT?"
    Add the weight of your tractor to it with fuel (And you) in it. You should get pretty close to a tare.
    JReding Thanks this.
  6. Loxboy1
    Loxboy1 Bobtail Member
    25
    5
    May 14, 2017
    Read the registration paper for the trailer, my 1000cubicfoot stephens showes 9300 on the paper but i think its closter to 11,000 because i know how much my truck weighs with fuel and when i get on the scales to get my light weight with 256gallons of fuel im at 29,860.
    Id guess your hiel is the same or a tad heavier because they use a heavier gauge aluminium for the tank then the stephens.
    When you get loaded you dont load ontop of a scale??
    Frank Speak Thanks this.
  7. ncdriver1
    ncdriver1 Road Train Member
    1,106
    1,252
    Dec 3, 2012
    i would guestimate around 14k empty, since its 3 compartment and only tandem axle. Your BOL should have weights on it, just look for "tare" and that should be your total empty weight (truck + trailer). Depending on your truck, there should be a sticker from the manufacturer with the empty weight of the truck.
  8. hagarcobra
    334
    747
    May 24, 2013
    You can probably do this same thing at a weigh station if you ask them nicely
  9. 77fib77
    77fib77 Road Train Member
    11,630
    76,613
    Jul 7, 2010
    St Louis
    Single compartments are in the low 13s I think
  10. Loxboy1
    25
    5
    May 14, 2017
    When i get back to my yard ill check what the “stamped” dry weight of one of my hiels says. Also its gona depend if your running 22.5s or 24.5s steel vs aluminum wheels.
  11. Hillbilly1987
    8
    Feb 11, 2018
    No I just load estimating how much I take from the holding tanks guesstimate til I unload at the refinery crude oil I been guessing 310 lbs per barrel
