How often do you grind?
Discussion in 'Experienced Truckers' Advice' started by ethos, Apr 7, 2013.
  1. ethos
    ethos Road Train Member
    4,252
    13,002
    Mar 3, 2013
    Fort Worth
    I am not talking the loud, this is my first day grind. Just anytime you get that slight noise and vibration. How often do you miss your perfect shift. For me very rarely except downshifting in low range. Then I often get a slight grind especially if loaded. Never thought to ask anyone this question, just curious.
  3. dschmidt201
    dschmidt201 Light Load Member
    289
    109
    Jan 6, 2012
    Chicago
    I suck at truck driving I grind all the time especially going into nuetral that's when I grind the most
  4. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    happens every now and then, hell it's not even me sometimes, truck just wants to be stubborn and not take the gear even on the easiest shift from 7 to 8 accelerating on the interstate, done it hundreds of times at the same rpm but for whatever reason in that moment it says nope.
  5. ethos
    4,252
    13,002
    Mar 3, 2013
    Fort Worth
    Lol, your right.
  6. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    It grinds at times, but it's never my fault. Stupid transmission.
    robinrene, critters, HotH2o and 6 others Thank this.
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    In a truck with an Eaton, I hardly ever grind a gear. The truck I am currently in, however, has a Meritor transmission, and, combined with the Cummins ISX under the hood (which drops rpm's extremely fast), I grind quite a bit.
  8. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    i'll grind when i'm tired sometimes. and sometimes when i split the gears to which i don't split that often. so i'm not used to the split.
  9. Trucker Bug
    Trucker Bug Light Load Member
    117
    86
    Jan 24, 2013
    California
    Every day. It happens. Doesn't mean you suck at driving. Sometimes it just happens
  10. SAMMY6969
    SAMMY6969 Medium Load Member
    371
    121
    Nov 12, 2011
    YEA I GRIND EVERYDAY.NOT ALL THE TYM ITS MY FAUGHT.ITS THE TRANNY SOMETYMS IT JUST GRINDS...BUTT I KNOW WHEN IM REALLY TIRED I SUCK..AND THATS MY TELL..ITS TYM TO FIND A SPOT AND SHUT IT DOWN....SO DONT worry ABOUT IT,AS LONG AS U KNOW WHERE GEARS ARE AND WHAT RPM U SHOULD BE AT...
  11. AchioteCoyote
    AchioteCoyote Light Load Member
    227
    165
    Jul 24, 2011
    West Jordan, Utah
    I knew it wasn't my fault! It has been that stupid transmission all this time! Thank you! Thank you!
    Justmom Thanks this.
