how to convert trans to split the top side
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tnloggingkid, Sep 24, 2012.
  1. tnloggingkid
    tnloggingkid Bobtail Member
    4
    i have a eaton 10sp. i was told by a tech at kw in nashville it could be converted by adding a couple airlines and a shift knob off of a 13sp. i would like to know if this is actually possible or if it was just the tech trying to sound smart.
    my trans model number FRO-16210C
    any help on this would be appreciated.
  3. Down under trucker
    Down under trucker Light Load Member
    145
    64
    Jun 22, 2012
    Brisbane, Australia
    I think only the 9 speeds can be converted not the 10 speed but am happy to be proven wrong
  4. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    some of the 9spds are convertable to 13spd but not a 10 spd
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    not 10 sp.
    really 9 sp may be converted to 13 sp changing cover and input shaft, but belive me it is easy to find 18 on JY
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ouh, not cover only.... more internals))) LOL
  7. Worthken
    Worthken Light Load Member
    265
    83
    Jun 2, 2012
    Delmas South Africa
    On a 9 speed you change the back section of the gearbox, the internals of the main box stays the same. Haven't seen it done on a 10 speed.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    9 speed transmissions were with other input shafts so you cnt use it on newer truck. As I've understood idea to purchase old 9 sp (cheap), coonvert it to 18 sp (using back section from toasted 18 sp), remove 10 sp and fit 18 зp (mad of 9sp).
  9. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    I have not seen an RT or RTLO series transmission that doesn't have a 2"x 10 spline input shaft, on one that is different is RTLO22918 which uses a 2"x 14 spline shaft.
    There is no way just to change airlines to allow a 9 spd to work as a 13 spd, there has to be splitter mechanism added to the back of the main case.
    tnloggingkid and bender Thank this.
  10. DieselDummy
    DieselDummy Light Load Member
    173
    62
    Apr 1, 2012
    Willet,NY
    If you have a 10speed, then that's it!!
  11. Ruthless
    Ruthless Road Train Member
    9,146
    90,734
    Aug 28, 2010
    The City.
    And that's it! Thanks for keeping it accurate!
