I bought a printer
Discussion in 'Ask An Owner Operator' started by 77fib77, Dec 6, 2019.
  1. 77fib77
    77fib77 Road Train Member
    11,607
    76,393
    Jul 7, 2010
    St Louis
    For 40ish. I needed over size permits.
    Down load permits to smart phone. Turn on printer wifi, connect with wifi on phone. Use hpSmart app to print. Too easy.
    IMG_20191205_021315393.jpg IMG_20191206_100903748.jpg IMG_20191206_100706809.jpg
    misterG, Dave_in_AZ, 88 Alpha and 2 others Thank this.
  3. D.Tibbitt
    156,695
    Does it work with an inverter. I just bought the same model but havent got around to hooking it up yet
    Dave_in_AZ Thanks this.
  4. 77fib77
    11,607
    76,393
    Jul 7, 2010
    St Louis
    . Yes off inverter.
    Yeah I have a harbor freight 2000 watt inverter. Why? You can return it anywhere in the USA.
    Dave_in_AZ and D.Tibbitt Thank this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,039
    17,145
    May 10, 2015
    Detroit, MI
    Try virtual reality. You will be blown away
    Dave_in_AZ, PE_T, Snake Farmer and 7 others Thank this.
  6. 77fib77
    11,607
    76,393
    Jul 7, 2010
    St Louis
    I'll have a heart attack.
    Wait a minute I c what your trying to do here.
  7. Ridgeline
    22,717
    122,891
    Don't let it get too cold or leave it in below 40 degree weather.
    Tb0n3 Thanks this.
  8. 77fib77
    11,607
    76,393
    Jul 7, 2010
    St Louis
    Ink?
  9. Ridgeline
    22,717
    122,891
    Yeah that's the problem injet printer cartridges can freeze and be ruined,
    77fib77 Thanks this.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had an inkjet printer in a truck for a few years. Problem was, the nozzles dry out if they’re not used at least weekly.
    I later put in a laser printer, black and white only. But it always worked. Laser printers do use a lot more power, but you have a large enough inverter.
    not4hire, Dave_in_AZ and PE_T Thank this.
  11. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Been using an inkjet for years, thru the winter. Never a problem. I thought the lasers were more sensitive to the cold.
    not4hire and Dave_in_AZ Thank this.
