I feel so stupid
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dphillips, Feb 7, 2014.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I have a Volvo 670 2007 with a Cummins isx I'm in Chicago its negative 9 degrees my truck sat up for 2 days I go to start the truck and the truck moves and does a half a turn on the starter I tried a few more times and I hear it working but won't turnover I call for a jump after a few hour of trying it stopped responding altoghther and then I remembered I had a guy change my windshield and he was the last person in the truck so I go in and check and yup the truck is in gear it wouldn't have started anyway but now I turn the key and nothing I wonder I burned out the starter
  3. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Do your interior lights still work? Old way to check was to put on your light and try to crank the engine. If the light dim or go out you've ran the batteries down. If they don't dim the starter isn't getting the signal. Probably have weak batteries and you killed them trying to start it in gear. Btw when the truck moves ahead when you crank it that a bad sign jk
    thelastrebel and Raiderfanatic Thank this.
  4. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Stupid is as stupid does, always push the clutch to the floor before attempting to start a truck.
  5. FordFan
    FordFan Light Load Member
    83
    31
    Jul 18, 2013
    As long as you learned your lesson. We all do silly things from time to time. Paying for the jump start is your payback.
    Raiderfanatic Thanks this.
  6. Diesel Dave
    9,651
    32,635
    Jan 20, 2010
    Hesperia, Ca.
    I guess thats the one "Right" thing I Have been all my trucking life, " ALWAYS PRESSING THE CLUTCH ON EVERY START" !!!!!! And........flipping the high low range splitter as well up and down.
    crb Thanks this.
  7. dphillips
    82
    8
    May 14, 2013
    The batteries tested all good but nothing when i turn the key I'm thinking the starter motor a wire or the solenoid went bad
  8. Diesel Dave
    9,651
    32,635
    Jan 20, 2010
    Hesperia, Ca.
    Have you tried by passing everything and try going to the starter directly ?
  9. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    i always just wiggle the stick to make sure its in nutral. i learned that after starting in gear with cluch in, then relcing clutch to have the truck jump and stall (luckily i had the parking brakes on.) Starting with cluch in doesn't help unless your gonna keep your foot on it untill u drive.
  10. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Well what do ya know, I've been doing it all wrong for 45 years, glad you straightened me out on this.
    JayTee, Diesel Dave and misterG Thank this.
  11. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Well if your smart enough to check your in neutral b4 taking foot off the clutch it helps lol, but if your gonna check the stick why not just do it b4 you start.
