I give up....
Discussion in 'CB Radio Forum' started by shivver, Sep 21, 2015.
  1. shivver
    shivver Light Load Member
    103
    48
    Oct 5, 2012
    Pennington,NJ
    I have been battling to have a working radio now for weeks....i have no idea what to do next. Here is the quick and dirty....
    2012 Prostar Midroof
    Galaxy DX959
    New high quality 18' coax
    New mount, sanded mirror strut prior to bolt-on
    Wilson 2000, 4 ft
    SWR is .2 on Ch1 and .3 on Ch40
    Antennae and radio are grounded to the chassis
    Symptoms: range of transmission AND reception is about 1/5 of a mile....at best. Squelch seems normal.
    Also, I have checked grounds in different locations, swapped antennas, swapped coax, swapped the mount, and tried a Cobra 29. Each radio was checked with different mics. All swaps were done one at time, to ensure troubleshooting accuracy. Its also not a "switchology" issue....I triple checked all positions on both radios and inline fuse has been checked and intact each time.
    The results are the same, no matter what I do. What am I missing???
  3. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    How is your power supply?
    shivver Thanks this.
  4. shivver
    103
    48
    Oct 5, 2012
    Pennington,NJ
    Its hooked up to the hotwire available from the stock setup....when i transmit, the needle flies just into the red zone....i do have some noise from the engine tho....
    Cottonmouth85 Thanks this.
  5. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    I would say ground to the frame hot to the battery and then check it. Those stock power supplies are junk at best
  6. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Disclaimer: fuse it on both ends and run wire through the cab appropriately. No need to go starting fires
  7. shivver
    103
    48
    Oct 5, 2012
    Pennington,NJ
    ok....will try....thanks
  8. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
  9. shivver
    103
    48
    Oct 5, 2012
    Pennington,NJ
    I tried a Firestik.....that didnt help.....i top loaders are supposedly better, but. i am a huge fan of the Wilsons. Do i need to run the same gauge wire to connect to my radio harness? I would imagine that a shift in gauge would produce "dirty" power....correct?
  10. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    No, 100 different accessories on the same circuit causes 'dirty' power. If you run a slightly heavier gauge you're stepping in the right direction.
    mike5511 Thanks this.
  11. shivver
    103
    48
    Oct 5, 2012
    Pennington,NJ
    Thanks! Am gonna run the hot and ground to the battery while i am waiting to offload tomorrow....i will report...
