I messed up. Over on Drives by 2K gross is 75K
Discussion in 'Questions From New Drivers' started by dboot01, Jan 20, 2026.
  1. dboot01
    dboot01 Light Load Member
    134
    224
    Nov 8, 2021
    I picked up a load in Kansas City going to Chicago. Im on i72e/us35e in Missouri
    I just scaled the load here before fueling and the drives are 38k with the tandems all the way up. Total gross only 75k ( that's why I didn't scale sooner, my bad)...anyway...
    Should I try to go back to shipper ( 200 miles) or go to Chicago? And how do I avoid scales houses? The shipper is in Edgerton KS ( close to Kansas city)
  3. SGIT820
    SGIT820 Bobtail Member
    37
    121
    Oct 18, 2025
    You won’t see a scale until you get to Bolingbrook on I-55. Depending on where you’re going in Chicago, you can probably run around that scale fairly easily.
  4. Speedy356
    Speedy356 Medium Load Member
    505
    3,143
    Oct 13, 2021
    Stay on I-72 E to spfld il, it’ll dump you onto I-55 North, no scale houses until you get up into Chicago. When you get to I-80, if you need to continue on 55 further north, jump off on I 80 east to I-355 north and take that up to I-55 north again. That’ll put you north of the north bound scalehouse if it’s even open. FYI I-355 is a toll rd.
  5. dboot01
    134
    224
    Nov 8, 2021
    Is there a scale on i294 north?
  6. Lonwolv54
    Lonwolv54 Medium Load Member
    378
    955
    Oct 23, 2024
    Always try to scale within 20 miles of your pickup if possible...obviously that was possible in this case..lesson learned.. @Speedy356 gave you the correct advice at this point.. Chicago land scales are mostly closed so you go lucky.. All The Best!
  7. Speedy356
    505
    3,143
    Oct 13, 2021
    To my knowledge, none of the toll roads in the Chicagoland area have a scalehouse.
    hope not dumb twucker and dboot01 Thank this.
  8. Speedy356
    505
    3,143
    Oct 13, 2021
    There’s north and southbound scales at Bolingbrook, and east and westbound scales at Joliet on I-80, but they are farther east on 80 if you want to run up I-355
  9. dboot01
    134
    224
    Nov 8, 2021
    I'll do 355 thanks
    Lonwolv54, austinmike and Speedy356 Thank this.
  10. austinmike
    136,396
    I used Truckers Path a lot to see where the scale houses were and if they were open or closed. Very useful tool.
    Ddh77777, JonJon78, tscottme and 6 others Thank this.
  11. TripleSix
    133,199
    Do you have a suspension gauge?
