I need help.... 22 freightliner
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Commuter69, Jun 1, 2024.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    I just got into the seat of this truck and the controls on the steering wheel got gunked up and sticky, IDK what it is, possibly a soda, that caused it... because of this, the controls don't work well, which is annoying...
    Any advice on how to clean the crap out?
  3. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    I know 2013 is just pull steering cover , disconnect 2 wires , remove side controls , clean and put back ...did mine , send pic
  4. FryDaddy
    FryDaddy Light Load Member
    56
    56
    Jul 27, 2018
    Chandler, AZ
    Maybe try a wet toothbrush, go over it and keep working the controls . .. . .
    Dave_in_AZ and Flat Earth Trucker Thank this.
  5. Dave_in_AZ
    422,922
    Just use water. And the toothbrush.
  6. 5UG
    5UG Light Load Member
    53
    46
    May 22, 2024
    I'd use electric cleaner, a wet wipe, and a toothbrush. Then another blast of cleaner. . . And let it dry.
    GoneButNotForgotten Thanks this.
  7. 50WT
    50WT Road Train Member
    2,948
    27,007
    Dec 26, 2015
    The electric cleaner works great , my window switch's get to were they won't work good . I'll pop the trim cover off and use this then let it dry really good ,always works for me. Screenshot_20240602_054855_Gallery.jpg
    5UG Thanks this.
  8. 5UG
    53
    46
    May 22, 2024
    Yep- that's it- that stuff does work great!
  9. Commuter69
    1,142
    635
    Jul 2, 2014
    I'm afraid that water won't mix well with the electronics inside?
  10. 5UG
    53
    46
    May 22, 2024
    Water would be fine to clean up the steering wheel itself, but water doesn't mix well with electronics. Grab a bottle of electric cleaner for the controls. It's ten bucks give/take. 50WT posted a picture.
    Good-luck to ya!
