I phone 12 case
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Side pipes, Dec 1, 2022.
  1. Side pipes
    Side pipes Light Load Member
    93
    72
    Nov 27, 2022
    Ireland
    I’m about to change cellphone to an I phone 12 what’s a good case with screen protector in and out of construction sites so need something strong preferably clip on
    To my belt
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
  4. Diesel Dave
    9,643
    32,573
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on the Otterbox Defender series, it comes with it all. However, the built in screen protector will get scratched and blurry from use in a short time(does it job). What I’ve done after it gets beat up(screen protector), I cut it out and replace just the screen protector.
  5. austinmike
    137,011
    Otter box defender is what I've used for 10 years. You can get one for a decent price on eBay or Amazon.
    Side pipes and Diesel Dave Thank this.
  6. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    I use Punkcase. It’s identical to Lifeproof but way cheaper.
    Rokform looks rugged. There are also metals ones that I saw online by Astra.
    InTooDeep and Side pipes Thank this.
  7. Banker
    Banker Road Train Member
    4,506
    14,562
    Aug 19, 2012
    I used the Otter Box for many years and really like how durable it is and had a belt clip case I used with it. I needed a thinner case that could be carried in my front pocket easier while loading so I tried this one. It works well and protects the phone great. The glass on the case isn’t as durable as the Otter Box so if you don’t need a thin case I would pick the Otter Box first, but I pick this one if you do need a thin case. I cracked the glass on this one early on and it looked like the phone’s screen was damaged but it was only the protective case. 3189B277-5D58-47F1-B537-973E54A87D1E.png
    jweebothee and Side pipes Thank this.
  8. Diesel Dave
    9,643
    32,573
    Jan 20, 2010
    Hesperia, Ca.
    FYI; I run skateboards, I leave my iPhone in the truck 99% of the time when I’m outside working on my loads. Just a precaution so I don’t damaged it or scratch it. That’s just me.
  9. Side pipes
    93
    72
    Nov 27, 2022
    Ireland
    I probably would go with the otter box as I want a strong thick Case Appreciate your recommendation
    austinmike and Banker Thank this.
  10. classic_150
    classic_150 Medium Load Member
    322
    246
    Apr 5, 2009
    South Dakota
    Otter Box Defender for me for many years. Leaving the phone in the truck is the best option, but not always possible. My iPhone has hit the pavement more than once and not had any damage thanx to OBD
    Side pipes and austinmike Thank this.
