I-shift faulty
Discussion in 'Volvo Forum' started by ah fai, Jan 8, 2013.
  1. ah fai
    ah fai Light Load Member
    178
    HI all
    Volvo fm12 I-shift come with fault codes (PTO #1 engagement) actuator (VAP1) electrical faulty - active
    MID130 PSID20 FMI5
    please advice.
    thanks.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    PTO solenoid disconnected. Check truck configuration, may be someone removed and sold all PTO stuff (pump, solenoids, tank) and use this trucktor to tow flatbed for example)))) was used with dampers before
  4. ah fai
    178
    Then what should i do? replace a PTO? where is the PTO solenoid location ? can off the function ?
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
  6. ah fai
    178
    sometimes cant go forward while gear shift into drive position, only can reverse.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    try to run I-shift calibration procedure with VCADs ore TT. Any faults would be found and fixed
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I sugest worn synchro ore bad tranny brake
  9. ah fai
    178
    Will do calibration very soon, the I-shift related with brake system? how about ABS wheel sensor or lining sensor?
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    only ABS sensors are important, becouse TCU compares front and rear axle speed to avoid shifting in sharp curves, so EBS data via J1939 is used
  11. Confused
    Confused Light Load Member
    224
    270
    Sep 22, 2009
    somewhere else
    I had to have sensor in tranny replaced last summer. The tranny would go up and down gears all day long till I stopped then it wouldn't engage in gear. After a few seconds it would engage in gear. Sometimes I had to shut off engine and restart before it would go in gear. It took 5 Volvo dealers before the problem was fixed. They changed everything out but the kitchen sink. Bad news you have to pay for these #### techs to learn on your truck.
    I had every excuse from weak batteries, weak starter I had , 4 new batteries installed, new starter, clutch solenoid valve, transmission wiring harness, and lastly the transmission sensor, which cured the problem.
    In order to install that sensor they have to drop the transmission.
