ICC BUMPER
Discussion in 'Experienced Truckers' Advice' started by Milechaser, Sep 12, 2019.
  1. Milechaser
    Milechaser Light Load Member
    82
    54
    Mar 8, 2014
    Campobello, SC.
    1F770F51-0F37-4DF4-ABEC-A3B1D388F156.jpeg 03A4613F-F2F3-4BE5-88B1-2C2CA4B4A2AA.jpeg
    Is this crack a DOT violation?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Not too bad.
    A good welder will hammer that out and bead it shut.
    And a plate welded over and under it so that if someone did slam into it you did your best to make sure that it is not a dangerous sharp instrument that will chop and hack in addition to taking the driver who ran into it's head off.
    88 Alpha Thanks this.
  4. wis bang
    wis bang Road Train Member
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    the rear under-ride protection needs to be maintained to the standards since the 90's
  5. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    picked from a mound of papers...
    Table 3—IIHS's Table of Its Front-Into-Trailer Rear Crash Tests; 2010 Chevolet Malibu
    Trailer Speed (km/h) Malibu's overlap with guard Guard ground clearance (centimeters) Guard performance Underride
    2007 Hyundai 56 Full-width 47.6 Attachments failed Catastrophic.
    2007 Vanguard 40 50% 42.2 Attachments failed Moderate.
    2007 Vanguard 56 50% 42.7 Attachments failed Severe.
    2011 Wabash 56 Full-width 44.5 Good None.
    2011 Wabash 56 50% 44.3 End bent forward None.
    2011 Wabash 56 30% 45.3 End bent forward Catastrophic.
    source
    Rear Impact Guards, Rear Impact Protection
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Depends on the dot officer, some would write it up some wouldn't. Technically yes
  7. buzzarddriver
    3,823
    11,528
    Feb 1, 2011
    Dallas, TX
    I would say, as long as there is a physical connection between the two pieces and not completely broken into, it would pass.
  8. Upinsmoke
    Upinsmoke Medium Load Member
    612
    1,206
    Feb 26, 2019
  9. Upinsmoke
    612
    1,206
    Feb 26, 2019
