Idle Change, Injector Knock?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Roteck, Mar 2, 2019.
  1. Roteck
    Roteck Light Load Member
    225
    100
    Dec 18, 2016
    Abilene, TX
    While idling there's a noticeable idle change that occurs occasionally. It's a 2015 KW T680 with a Cummins ISX that's deleted. I had a pickup that was deleted and the first tune on it was a bad tune and I learned what injector knocking sounds like. The sound my KW is making is similar. Sometimes it begins sounding like injector knocking randomly and idle fuel usage goes up about .3 gal/hour. Then after a few minutes it goes back to normal. Continuous cycle between normal and what sounds like injector knock. I'm just wondering if it it a sign of dirty or bad injectors or a sign that the tune on here is trash. Either way looking at big $$$ repair. What are some things that can be done to diagnose the injectors? Someone also told me that this model Cummins sometimes does some weird stuff when injectors are dirty. The thing that caught my attention is they said the coolant fluctuates when injectors are clogged/dirty. What's the link between injectors and coolant? Why would clogged/dirty injectors cause coolant to do anything? My coolant absolutely fluctuates frequently since I get low coolant warning all the time. Dealer said it's likely the wiring since I've replaced the reservoir and sensor. Couldn't fine any breaks in the wire so I just live with the warning. Based on what this person told me about the injectors it may all be related. I've also noticed a significant decrease in fuel economy lately. It's all stacking up, just trying to put my finger on it.
  3. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    You sure it’s not just the compressor kicking in and out? Compressors can sure nuff knock and sound like an injector.
  4. Roteck
    225
    100
    Dec 18, 2016
    Abilene, TX
    Yeah it's not the compressor. That knock is similar but this knock is definitely injector knock. It sounds almost exactly like it did on my 6.7 cummins. Except the 6.7 had it all the time.
  5. 062
    062 Road Train Member
    6,275
    33,779
    Oct 20, 2013
    Have to hook a laptop to it and turn off injector one at a time. Hopefully it’s just a injector going bad and not the tune.
  6. Roteck
    225
    100
    Dec 18, 2016
    Abilene, TX
    Alright. I've got a trustworthy place to take it to to get some accurate results. What does an injector replacement or cleaning usually cost? Rough estimate.
  7. 062
    6,275
    33,779
    Oct 20, 2013
    Its been nearly four years since I priced a isx injector. You can get the serial number off the motor and call around. On your truck I would guess 2-3 hours labor to replace injector.
  8. Roteck
    225
    100
    Dec 18, 2016
    Abilene, TX
    OK thanks. I'll post what is discovered around the 14th
    blairandgretchen and 062 Thank this.
  9. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    Run a tank with Lucas injector cleaner through it.
