Idle time
Discussion in 'Freightliner Forum' started by Ei, Sep 11, 2013.
  1. Ei
    Ei Light Load Member
    79
    7
    Aug 18, 2013
    Northeast
    How long do you let your truck idle in the morning unloaded before taking off down the road?
  3. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    During my PTI I'll start it after checking the oil. Give it 5 minutes at low idle, crank it up to 900 for another 15 and then hit the road. My temp at that time is usually 125 on water and 125 on the oil. I keep my foot out of it and RPM low until it heats up though. Once she's hot I run hr like normal. Before I had a truck that actually warmed up in a reasonable amount of time in the summer that was all it took to hit 160 on the coolant temp. My truck takes longer think the thermostat needs replaced not 100% sure but I can let it turn 900 all night in the summer and it'll never get above 150 on the water temp oil temp might hit 175 if I'm lucky. Other truck runs about 210 and 220 on the oil temp going down the road. Idling it'll warm up to 190ish and hover. Fan comes on every 30 seconds too.
  4. crosscut
    crosscut Light Load Member
    226
    126
    Feb 23, 2009
    FL
    Never turned mine off..but back in the day we didn't have apus ;)
  5. Buckeye91
    Buckeye91 Road Train Member
    1,095
    677
    Sep 26, 2011
    Midwest, USA
    nor was it such a big deal to idle/use fuel. Now companies make it a huge deal. One example is Prime going 55 down a 70mph high way, I consider that a hazard.
    Smaggs Thanks this.
  6. 25(2)+2
    18,759
    45,960
    Sep 18, 2006
    the road less travelled
    If it's really cold, I idle it till the temp gauge moves, which is about 100 and drive it easy until it warms past 175, it doesn't take long.
    In the summer, I go in to hook a trailer as soon as the air builds enough to unlock the parking brake, and it warms past 100 almost immediately. This is a low specced DD15.. I used to warm a Series 60 more. And a N-14 Cummins more yet.
  7. morr2fab
    morr2fab Medium Load Member
    338
    110
    Oct 3, 2012
    10 minutes and then I'm on the road. 2007 freight, I never push it when it's cold.
  8. Ezrider_48501
    3,845
    5,134
    Apr 2, 2011
    bismarck, nd
    i like to see at least 150 on the gauge before taking off then drive it easy up to normal operating temp.
    start it after 60 seconds or so bump the idle up to 1000
  9. Dorsey
    Dorsey Medium Load Member
    412
    209
    Jan 28, 2012
    Florida
    I wont move the truck until it reaches 150 at least.
  10. 379exhd
    2,925
    3,153
    Jun 25, 2012
    Rodding a cold diesel is never a smart thing to do. sometimes I just shake my head watching cowobys right after they fire their truck up take off...IN THE WINTER! I suppose when they lose a turbo because the oil was too cold to get to the turbine shaft they'll learn.
  11. Ezrider_48501
    3,845
    5,134
    Apr 2, 2011
    bismarck, nd
    that or the guys that come right in off the highway and shut there truck off without idling it out fist. good way to take out turbo bearing always let your truck idle till egts are below 250 before shutting it off. or your burn the oil that's sitting in your turbo bearings causing a buildup over time. thus taking out your turbo
    the biggest issue with not letting your truck warm up isnt so much the turbo as it is the pistions/rings and bearings your pistons will heat up much faster than your liners running the truck under load during warm up and engin bearings are designed for proper clearance at operating temperature. has less to do with your oil than you think, oil is properly circulating threw everything within the first second.
    MazelTruck and razor1983 Thank this.
