Ignition fuse blowing
Discussion in 'International Forum' started by Josh88, May 21, 2018.
  1. Josh88
    Josh88 Bobtail Member
    I have a 2007 Internaional 4300 with dt466 bucket truck , runs fine with pto off but when on and running the bucket it will blow the 5 amp ignition and diagnostic port fuse ,followed wires from ignition and dlc connector to fuse panel in dash and didnt notice and broken or bare wires I'm a bit stumped any info orbpointers would be great
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I would suspect someone has wired power for the PTO from this fuse source and it is now shorted somewhere when engaged. That 5 amp fuse only powers your diagnostic port and ignition relays from the key switch. So follow A15 as best as possible and check for anything tapped into it that shouldn't be.
  4. Abcauto79
    Abcauto79 Bobtail Member
    What a15 .
