I'm confused
Discussion in 'CB Radio Forum' started by Superquack, Aug 8, 2015.
  1. Superquack
    Superquack Medium Load Member
    338
    116
    Mar 7, 2010
    Well got cb hooked up yesterday and nothing. I get power and it does turn on. But on the meter it doesnt register anything, even when keying the mic. Only get sound with squelch all the way up and RF set at max. Perhaps too small of a power wire. Its the 20 gauge found at wilco.
  3. bandit74
    bandit74 Light Load Member
    148
    92
    Jul 4, 2015
    Sounds like coax, antenna cable is not grounded / hooked up
  4. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Always eliminate the mic first....i.e. try a different one.
  5. Superquack
    338
    116
    Mar 7, 2010
    Will try the mic first, since its the easiest. The coax is RG-58, was already in the truck when i got it, so just used it.
  6. Superquack
    338
    116
    Mar 7, 2010
    Although any tips for running an antenna ground?
  7. rabbiporkchop
    9,689
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Try flat braided ground strap
  8. Xcis
    Xcis Medium Load Member
    498
    270
    Jul 9, 2008
    Bridgeport, Pa
    First try a known good mic.
    You stated that you are using RG58 coax. That is one of the correct coax cable types for when you are using a single antenna setup. You are using a single antenna, right? You are not trying to use RG58 with a dual antenna setup, right?
    . If a good mic does not fix the problem, can you borrow some known good coax cable and use that temporarily to check if you can get the CB radio setup working correctly? You can use RG58 or RG8. For CB radio it makes very little difference.
    .Do a physical check of the length of the coax for breaks and/or odd lumps that would indicate a break in the coax.
    .If you could not get different coax to try out, you need to get someone to check the coax cable with a multimeter. Check the resistance of the center wire from one end to the other end. It should read zero. Then check the resistance of the outer shield from end to end. It should read zero. Check the center wire to the outer shield at the other end. It should read maximum resistance.
    For an antenna ground plane problem there are two options.
    .Option 1 install flat braid straps. Do a search for antenna ground plane for the specifics on what to do.
    .Option 2 install another additional CB radio antenna mount facing downward. Install a second antenna only this one facing downward and check your SWR reading with an external SWR meter.
  9. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Don't use the plastic washer on the antenna pointed down with no coax....must be completely grounded to the mount.
