inconsistant smoking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cuzzin it, Nov 16, 2014.
  1. cuzzin it
    cuzzin it Road Train Member
    3,642
    12,278
    Jan 19, 2008
    Berea, KY
    Have a 2010 isx that smokes in top gear when pulling..... sometimes. not that often really, no dash lights showing up, loss of power or other problems. Just light bluish smoke till the turbo winds down. Sometimes it will go for weeks before happening again, other times it's few times a week.
    Any guesses ?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    Trucks with lazy or weak DOC will start to smoke like this when the unit is regening. Since the regen happens only when the system is needing one, it can be a hit and miss phenomena. One way to know if it is regen related is to come to stop when you notice the smoke. During a regen the high exhaust temp light will come if the truck is moving at less than 5 mph. If you stop and the exhaust temp light is on you know it was doing a regen.
    magoo68 and cuzzin it Thank this.
  4. cuzzin it
    3,642
    12,278
    Jan 19, 2008
    Berea, KY
    stops as soon as i lift off the pedal it's only when pulling a hill or accelerating with heavy load
  5. sailboatjim
    sailboatjim Light Load Member
    292
    173
    Aug 27, 2014
    Boston, Mass
    What color is the smoke?
  6. cuzzin it
    3,642
    12,278
    Jan 19, 2008
    Berea, KY
    white with a bit of blue
  7. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    White is usually coolant.....blue usually oil. Burning coolant burns the #### out of your eyes.....useless test on a truck with stacks tho lol
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Heavy d probably has the right answer .. Also when pulling a hill or a heavy load you make more exhaust heat which starts a passive burn if needed .. I've seen a few guys I know smoke bluish when a passive burn is just starting but once going it cleans up .. My guess is shortly after you notice bluish smoke truck pulls better due to dpf being less restrictive after burn off
    Heavyd Thanks this.
  9. KC Guardrail
    KC Guardrail Light Load Member
    199
    155
    Dec 7, 2013
    Like heavyd said, sounds like a rolling regen. The 2010s still dumped fuel down the exhaust to heat up the DPF.
    Heavyd Thanks this.
  10. BigYellower
    BigYellower Bobtail Member
    30
    Mar 18, 2012
    Sammamish wa
    Might have a clogged EGR cooler, or DPF filter ..
  11. sailboatjim
    292
    173
    Aug 27, 2014
    Boston, Mass
    I agree See this quite a lot.
