Info please
Discussion in 'Freightliner Forum' started by dcwjr, Apr 3, 2014.
  1. dcwjr
    dcwjr Light Load Member
    58
    Jan 11, 2013
    09 cascadia with mercedes sid 80 fmi 5??? Engine light on constantly
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    I show Jake Brake Stage 2 Circuit Failed Open for SID 80 with an FMI 5. Could be wiring or a bad solenoid. Give a god lookover of the wiring from the head to the ECM, if all looks good there, the next step is under the valve cover. You can check the solenoid with an ohm meter. I don't know the spec, but it should be the same as stage 1 (that isn't setting a code). Also check the wiring under the valve cover. If the solenoid is open, there's your problem. If it's not, you have a wiring poblem to track down.
