Information and Help Needed
Discussion in 'Ask An Owner Operator' started by Rookie2020, Feb 2, 2024.
  1. Rookie2020
    Rookie2020 Bobtail Member
    35
    24
    Sep 22, 2020
    I have a 2008 Freightliner century with 60 series engine. I changed the coolant surge tank place from the radiator to firewall on the driver side, the same as in 2005 freightliner century. during work I broke the plug in pigtail. I bought a new one but I do not know where the power wire goes. I tried both sides and it is giving me the error on dashboard ENG Coolant level Sht Hi 128 111 03. Does the power wire go on the right or the left side when you are facing the sensor?
    Help and suggestion are appreciated
    Thank you
    austinmike Thanks this.
  3. Ridgeline
    22,720
    123,260
    I would go to the dealer with your VIN, have them print up the wiring diagram (they normally do this for free), and see what you need.
  4. Rookie2020
    35
    24
    Sep 22, 2020
    I fixed the plug in but now it tells me coolant level low 128 111 01. What do I do now? Where do I start?
    austinmike and Rideandrepair Thank this.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Sounds like you bought a used tank 3 years earlier. It's possible the sensor is bad in it.
    Rideandrepair Thanks this.
  6. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    I’ve had more problems with this sensor and the pigtail itself than anything else on my Freightliner/Detroit. Jump the plug, paperclip works best on mine. I’ve twisted wires together. Same thing. I don’t think it matters which way the wires go. If the code goes away . It’s usually the sensor. Usually can change them without losing much coolant. Work fast. Sometimes a good cleaning will do the trick. They get an invisible film on them sometimes.
    NYStarcar and austinmike Thank this.
