Injectors leaking, underpowered 3406E
Discussion in 'Ask An Owner Operator' started by Marmon110P, Dec 1, 2025.
  1. Marmon110P
    Marmon110P Light Load Member
    192
    189
    Feb 24, 2019
    3406E 5EK Has anyone had over fuelling and under fuelling symptoms at the same time?? When i start the truck it will fart n buck for a few seconds like injectors are leaking n then smoothen out. When I drive it n put my foot down, it will make up to about 15 psi of boost n then drop back to 10 psi after maybe 20 seconds (but only intermittenly about half the time), and shake like its running on 5. I took the manifold off and found #5 n 6 wet, so I replaced those injectors, but still having this same issue. ET says everything looks good electrically wise. Also while its idling it has some haze out the stacks like its running rich. New APC head 4 months ago n then he haze issue showed up around the same time
    Opendeckin Thanks this.
  3. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
  4. Diesel Dave
    9,640
    32,555
    Jan 20, 2010
    Hesperia, Ca.
    Any codes ? With the cruise on and off switch off, hold the set cruise toggle for about 5 seconds up or down and the check light should flash in 2 sets, if it flashes 5 times, pause and 5 times again, it’s means 55 which is good, no codes, if it flashes like 4 then 3, it would be 43, that’s an example. Once you find the active code, look it up. Unless you have the Cat ET.
