Installed locking diff but it’s not locking!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JamesMc84, Dec 15, 2020.
  1. JamesMc84
    JamesMc84 Bobtail Member
    45
    Mar 20, 2017
    installed a locking diff in the rear drive axle, seemed to work before I installed. Put air to it. Sucked in the forks on passenger side. Had to installed it hooked fox air to clear housing. Now it’s in the truck when I put air to it I can’t hear any movement? And it’s definitely not locking the wheels.
    What could be wrong?
  3. Milr72
    Milr72 Medium Load Member
    578
    1,419
    Dec 16, 2011
    S W Missouri
  4. lester
    2,955
    8,061
    Jan 2, 2012
    NW, Iowa
    Not that it would help with it not locking but did you have to cut any clearance out of the housing? On my eaton 404s I had to cut a notch to get it to fit and it wouldn't have had room to unlock without it
    pushbroom and AModelCat Thank this.
  5. AModelCat
    163,726
    Used the proper axle with the longer splines?
    Collar didn't fall out on you? Supposed to install the carrier with the locker engaged.
    lester Thanks this.
