Installing a power inverter
Discussion in 'Experienced Truckers' Advice' started by joshmck1982, Jan 8, 2009.
  1. joshmck1982
    joshmck1982 Light Load Member
    89
    12
    Jan 7, 2009
    Greensburg, IN
    Is wiring a power inverter to the truck batteries hard? If I'm a company driver, is it something that I should have done by one of the company's mechanics or can I do it myself?
  3. Lilbit
    Lilbit Road Train Member
    16,583
    12,233
    Aug 4, 2008
    Let me check my logbook
    If you're a company driver, you'll have to see what their policy is. Some companies don't allow them at all. IF they do allow them, a lot of companies require that their mechanics install them.
  4. Bigray
    Bigray Road Train Member
    1,135
    383
    Nov 23, 2007
    Tampa, Florida
    pretty easy actually, just make sure to install a fuse box in the line.
  5. thomas
    thomas Light Load Member
    131
    13
    Jun 29, 2007
    Athens,Al.
    also make sure you use the proper gauge wire.
  6. kewl_mekanik
    kewl_mekanik Bobtail Member
    28
    6
    Jan 14, 2009
    Pensacola,Fl
    Follow the Destructions on the users manual,,red to red black to black,,ground lug to chassis grnd,,E Z Sleazy Miss Trapeeezy U Can Do IT ! ! ! !
  7. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    It would be advised to install a fuse as close to the Bat as you can. That way if the wire comes undone and grounds out, you don't have a fire.
  8. Hammer166
    7,601
    27,763
    Aug 18, 2007
    ~8600+' and loving it!
    In a lot of company trucks I've driven, a fire wouldn't be a bad thing!
  9. PharmPhail
    PharmPhail Road Train Member
    3,084
    1,125
    Nov 7, 2008
    NC
    An in-line circuit breaker within 12" of the battery would be better than a fuse.
    Wiseguywireless Thanks this.
  10. doubledragon5
    doubledragon5 Road Train Member
    2,935
    4,088
    Jun 8, 2008
    Lewisville TX
    Personally unless your rich and can:
    1) Afford to pay for the replacement of the truck/trailer/load
    2) Afford to be put out of work because of your desire to put in a inverter that you have no business doing.
    3) Pay for the fire department to come out and put out the fire, when they could be doing something more useful ( like getting a kitty out of a tree)
    4) Willing to work for the rest of your life, (that's only if your not RICH) as a Wal-Mart greeter just to pay off what you destroyed.
    Then don't, let a professional do it for you..
  11. PharmPhail
    3,084
    1,125
    Nov 7, 2008
    NC
    All right no sense in getting paranoid. You're not wiring it into "the electrical system" like people think. You run the hot STRAIGHT from a battery to the inverter through a drilled hole in the cab and ground the inverter inside the cab. No other wiring is touched. You're not gonna blow out your headlights and cruise control or some other such nonsense.
