insulating a 359 Pete
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, May 23, 2014.
  1. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    I have an '86 359 with a flat top bunk that I bought a little while back. It's in really good shape but it appears to have no insulation or soundproofing whatsoever. Any suggestions on what I can use to make it a little quieter and cooler/warmer?
  3. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    dynamat, hushmat, lizard skin... they're all great products
    bigguns Thanks this.
  4. Ezrider_48501
    3,845
    5,134
    Apr 2, 2011
    bismarck, nd
    iv thought of gutting the interior of my old fld and spray foaming it and then putting it back together
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    We dynamatted the floor of my 379 years ago. It cut the noise by 10 dbs IIRC. I would pull the interior and put some by the stacks in both the cab and sleeper and the headliner also. Some on the firewall will also help.there's lots of options out there if you don't feel like dropping 400 bucks for dynamat. I used peel and stick roofing insulation on the floor of a vw beetle and noticed the difference.
  6. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Read up on insulating materials. Then make your choice. Some materials help with both noise and heat. Some help heat/cool but make the noise worse. Some will reduce the noise and do nothing with the heat/cool situation. I put spray foam inside the struts of my KW sleeper. Then I used a thin shiny silver bubble like insulation from Lowe's for the walls, roof, etc. That 1/4" insulation material but it H_ _ _ to get the upholstery back in. That combination helped a great deal but I will probably use Dynamat or Hushmat for the cab.
  7. rank
    9,919
    113,510
    Feb 11, 2010
    Is the Dynamat etc stuff good for thermal insulation as well or just noise?
  8. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    I'd say both heat and sound, plus you can find varieties tailored to your needs.
    Dupli-color also has aerosol and brush/roll-on bedliner that may help to some extent.
  9. special-k
    1,523
    3,258
    Dec 27, 2008
    The dynamat we used was mostly for noise but I think the newer stuff does both. In the bug I put foil backed bubble insulation on the inside of the roof because it didn't have a headliner and it worked well. The factory heat insulation in my 379 looks similar.
  10. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Hushmat in mine, made a huge difference. Don't forget doors.
  11. peterleader
    peterleader Bobtail Member
    6
    4
    May 24, 2014
    Here's what you do:
    You go and get like 50 chickens and pluck there feathers and stuff them in the interior.
    When have you ever seen a chicken be cold or hot?
    Big_D409 Thanks this.
