Intermittent Vibration/Wobble
Discussion in 'International Forum' started by Bill43452, Apr 25, 2012.
  1. Bill43452
    Bill43452 Bobtail Member
    34
    2007 Int. 9400i 520,000 mi. Can feel wobble/vibration intermittently but not in steering mainly in the floor. I feel it more when empty than loaded. Had carrier bearing replaced last week and wobble/vibration still exsists. Checked for play in the slip joint and the universals and they all seem to be tight, and front axle wheel bearings were replaced last month. I am at a complete loss any ideas or suggestions would be appreciated!! Thanks
  3. Bill43452
    34
    2007 Int. 9400i 520,000 mi. Can feel wobble/vibration intermittently but not in steering mainly in the floor. I feel it more when empty than loaded. Had carrier bearing replaced last week and wobble/vibration still exists. Checked for play in the slip joint and the universals and they all seem to be tight, and front axle wheel bearings were replaced last month. I am at a complete loss any ideas or suggestions would be appreciated!! Thanks
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Check the drive tires,tourqe ARM bushings I like to drop the driveline and check the needle bearings they might seem tight then you drop it and the inside of the cap and yoke are chewed up from lack of grease
    Bill43452 and MNdriver Thank this.
  5. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Check ride height on rear, steer tire balance and for out of round, cab mounting and suspension.
    Bill43452 Thanks this.
  6. Graglor
    Graglor Light Load Member
    62
    15
    Aug 17, 2011
    Langley, bc.
    The above posts are bang on. Any new work done? Tires? Sounds like a leveling valve/ ride height issue to me. Do you feel it in the stick?
  7. Bill43452
    34
    I do feel it in the stick, It had new tires and brakes all the way around it when I bought it and they are not top of the line tires. I have had the truck just about 2 months and the longer I have it the worse it gets. Under 50 mph I don't seem to feel anything and over 50 mph I feel the vibration/wobble, and it comes and goes. I checked the ride height and it seems to be fine, and I checked the torque arm bushings and they seem to be fine also. I do know for a fact that the spring shackle bushings do need replaced.
  8. Dino1968
    Dino1968 Light Load Member
    Cumming through the stick makes me think it's in the tranny or driveline. Could even be as far away as the rear diferential. I had a T600 with a Super 10, and for a loooong time had a rattle in the shifter. You know one of those that don't rattle anywhere else but where it wants to rest naturally going down the road !!!! :biggrin_25510::biggrin_25526:
    Anyway finally cooked my rear diff cause it had literally rusted through in a couple places to where the oil would slowly leak. Well with 4 other trucks to keep track of,you can figure out what happened. So I replaced the rear diff and the first thing I noticed after doing the job and taking her on a test run was that darn rattle in the gearshift was gone !! So your problem may be treansmitting through the driveline. IMO !
  9. Bill43452
    34
    The vibration ended up so bad I stopped at what ended up being a great shop in Lexington, KY. The input shaft bearing was wasted. They replaced the bearing, input shaft and 3 spider gears. $1450 and 5 hrs. later I was back on the road! Thanks everyone for their replies!!
  10. jab8283
    jab8283 Bobtail Member
    38
    16
    Jan 16, 2010
    Indiana, U.S.
    There is one more area which 99% of people miss and can damage not only engine, but transmission, drive-line and input shafts as well. It's as simple as that crankshaft damper bolted to front of engine which all fan belts originate. While 520,000 miles is relatively a young engine, fact is these dampers must be replaced every 500,000 miles. These dampers do and will fail and resemble a wheel or driveshaft out of balance. These are fairly easy to replace but something which must be on your maintenance radar. You will not know when they fail, but if you simply have them replaced every 500,000 miles you'll never have to find out when they quit working but when they do fail, they can cause many thousands of dollars in damage to engine and drive train. They only cost $500 - $700 dollars and are worth the investment for long running trouble free operation. A failed damper will snap a crankshaft, and can snap a drive line input shaft. It mimics a bad u-joint and you will feel it in the seat bottom. Just something I want all mechanics and owner-operators to think about.
  11. Bill43452
    34
    thank you so much for the new info. is this something I can check to see if it is bad?
