International 4700 dt466e with 333 code
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by basche llc, Jun 8, 2025.
  1. basche llc
    basche llc Bobtail Member
    I have a 2000 international 4700 with dt466e that has code 333. I replaced the ICP, IPR, HPOP, CMP, injectors were new last fall and pass the air test.All OEM parts. it has a miss when hot and blows smoke once the smoke is cleared out it runs better. it runs great cold. it use to take all day to act up now just 20 min it will act up. if the truck is turned off and back on it runs good for awhile even hot. any ideas???
  3. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    How many engine hours?
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    So that code is the ICP is not able to maintain desired by more than 400 psi plus or minus for longer than 7 seconds. It would be great to know if you have pressure too high or too low.
    Simple things first, check your oil level.
    Any other codes?
  5. Star Rider
    Star Rider Road Train Member
    1,787
    18,529
    Sep 23, 2019
    You would be amazed at how many DT466E and Cat 3126's got towed into the shop I worked at, topped off the oil fixed them. :violent1:
    Heavyd Thanks this.
  6. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    How worn is the injector pass through connector at the valve cover?
