International 4800 - 4x4 system explained
Discussion in 'International Forum' started by weekenderdefender, Apr 2, 2025.
  1. weekenderdefender
    weekenderdefender Bobtail Member
    4
    Just acquired an older 4800 4x4. Curious about the 4x4 systems in International 4800s. Front driveshaft spins while driving and there’s a front axle IN/OUT button. Without me having to jack the truck up and test myself, what does the Front Axle IN/OUT button do? Assuming it either locks the hubs, or locks a center diff in transfer…or would be great if it locked the front axle altogether but that seems too good to be true.
    Thanks
  3. weekenderdefender
    4
    This is also assuming everything is working and the front driveshaft is supposed to be spinning…unless it’s stuck in 4WD. I have seen AWD emblems on some of these Internationals so I’m assuming the front driveshaft is always spinning with the rear.
  4. Heavyd
    Heavyd Road Train Member
    7,804
    6,249
    Feb 4, 2009
    It should have a transfer case to connect the front drive to the transmission. The drive shaft will spin normally as this part is all regular drive line parts to the axle housing with a differential gear inside that will spin full time with the wheels.
  5. weekenderdefender
    4
    Copy so the Front Axle IN/OUT button is basically a center differential lock/unlock. Front Axle IN = power to front axle. Front Axle OUT = no power even tho driveshaft spins since there aren’t manual locking hubs correct ?
  6. weekenderdefender
    4
    Also just to confirm these aren’t AWD systems?
  7. Heavyd
    7,804
    6,249
    Feb 4, 2009
    You are correct. Not full time awd unless you select it.
