International LT Blower Issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bugsy1108, Feb 19, 2021.
  1. Bugsy1108
    Bugsy1108 Light Load Member
    63
    18
    Mar 20, 2019
    2018 International LT
    Intermittent front blower problem.
    A few weeks ago blower was not turning on at all. Found the circuit breaker tripped.
    After resetting it, everything appeared to function normally.
    About 10 days ago we started noticing the blower would stop, start, change speed during normal operation. Heat/AC does not seem to matter.
    Also the fan speed frequently does not correspond with the control knob.
    Strange as it sounds the blower is frequently running when the truck is not turned on. When this occurs the blower does not respond to control knobs in the front or in the bunk. And blows mainly cold air.
    Often the blower will run whenever the Espar heater is on. This is an air heater, it does not integrate with the ducting so it shouldn't do that I expect.
  3. Bugsy1108
    63
    18
    Mar 20, 2019
    Quick addition, Sometimes the blower will not work at all but then starts again after the truck has been off.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    The tripped breaker would point to a shorted/failing blower motor. The erratic speeds would need further testing, but still pointing towards a bad motor. As far as the operation with the Espar, it is programmed to come on in the front on low, on cold when the bunk aux heater is turned on to prevent stale air and condensation from forming in the front cab.
    Bugsy1108 Thanks this.
  5. Semi Normal
    Semi Normal Bobtail Member
    17
    7
    Jul 29, 2019
    I have a 2022 LT that has a similar issue. The blower motor slowly faded out one night and has not come back on since. I bench tested the blower motor and it works like crazy. Our local dealership in rural Canada is somewhat useless. They told me it was the blower motor. Company hasn’t gone back to that dealership since. We switched the blower motor out with a known good blower from another truck. Still won’t work when hooked up to my truck. Also swapped out dash switches and still nothing from blower. Circuit breakers under that dash panel up front are all good. Have also replaced the resistor. Any of you have any suggestions?
  6. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Pull the breaker out and see if the terminals in the fuse box look like they have been hot.
    Heavyd Thanks this.
