1. International2020
    International2020 Light Load Member
    62
    12
    Dec 17, 2023
    South Carolina
    OK, so does anybody have any ideas? What the problem could be with my inverter? I’ve already swapped out for a new inverter I’ve even got temporary cables to wire up to try to see if it was the cables and the batteries are less than a year old, but the inverter is only getting 11 1/2 V. The truck shows. I’m getting 14 V when it’s running so does anybody have any idea what the issue could be because I don’t know anything else at this point
  3. beastr123
    beastr123 Road Train Member
    2,947
    24,178
    Jan 2, 2014
    Moose Jaw SK CAN
    Where is it connected to the trucks electrical system and what gauge of wire is connecting it?
    No inverter over 500w should be plugged into a cig lighter outlet or connected with less than #12 wire. Up to 1500w can function reliably with #8 wire. Anything larger should be connected directly to the battery box with minimum #4 cable and fused at the battery box. All connections over 10ft wire run go to the next size larger wire/cable.
    Also clean your battery terminals and ground connections at least twice per year (I did mine the weekend of the solstices) the dash gauge reads alternator output not battery condition while running, it reads battery output with key on not running only. 13.8v to 14.2v is standard alternator output, 12.4v to 12.8v is battery condition not running. Any not running reading less than 12.1v is normally due to poor battery condition or poor connection.
    Tb0n3 Thanks this.
  4. International2020
    62
    12
    Dec 17, 2023
    South Carolina
    Yeah, it’s all connected directly to the battery and I have zero gauge wire I believe and it’s only running a few feet but yeah, I mean I’ll check the battery gauge without the truck running and see what it says but these batteries are less than a year old
  5. International2020
    62
    12
    Dec 17, 2023
    South Carolina
    That’s without the truck running
  6. microtrucker
    microtrucker Bobtail Member
    8
    ok you need your inverter hooked up with one wire on one battery and the other on the battery beside it. no it will not give you 24 volts as you have a bus bar on all your batterys to run them together to give you 12 volts. things is the only reason your getting 11.5 volts on the inverter is you got it wired to one battery thats not how it works. it has to run off the system to work. do not run your inverter without a apu or the truck running. it will ruin your system batterys included. zero gauge wire is fine. problem is how you have it wired in
  7. International2020
    62
    12
    Dec 17, 2023
    South Carolina
    So I got it fixed. The issue was I had bad batteries two batteries were dead and two needed recharging.
    Iamoverit Thanks this.
  8. International2020
    62
    12
    Dec 17, 2023
    South Carolina
    Nvm I did not fix it. Worked fine till I went to go use my skillet now it’s doing low dc output again I’m getting really annoyed. Any other ideas. Literally everything has been ####ing changed out now
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    What is the inverter rated at?
    How many watts?
  10. International2020
    62
    12
    Dec 17, 2023
    South Carolina
    2000 pure sine
  11. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Should be big enough to power anything you can plug into it.
    Two things I have experienced with lower voltages than expected:
    - alternator had burnt rectifier on one of the phases, it seemed to put out proper voltages at low loads. When a heavier load was applied (my microwave or all the lights at night) then it showed low voltage.
    - bad cable or crimped lug, wire had an oxide coating on it that insulated the copper from making a good contact with the lug that was crimped onto it.
