is my MBN right?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Sodapop, Oct 9, 2010.
  1. Sodapop
    Sodapop Light Load Member
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    I have a 2004, 5.25 mbn cat.. Runs pretty smooth on idle,smokes to a good haze going up Hills(mt eagle) doesnt run Hottthough,..but it will charcoal the tips of my stacks.. I drive a flate top 379 pete,with a flatbed trailer...to me it seems it burns rich.. Im getting about 5 1/4 mph..does this sound right for a mbn 5.25 hp.. Thanks guys for any response..
  3. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    Sodapop Thanks this.
  4. Sodapop
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    yea,I have been reading that..i had my ecm checked out and its a 5.26hp with 1860 torque.funny #'s but that is what they said..really only thing that concerns me is the xtra smoke. It keeps my straight pipes chalked up pretty good.Gonna try the fuel wire and see what happens and get my injectors codes changed..
  5. josh.c
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    I think that's supposed to be kinda normal for MBNs, but I have no experience with them myself. If you're going to find someone to change the injector codes, you should really consider just getting Mr. Haney to go ahead and flash it for you. It's very reasonable for the results.
  6. rollin coal
    rollin coal Road Train Member
    13,617
    27,991
    Mar 29, 2008
    TN
    That sounds pretty good for an MBN do you hand calc it? You're lucky your egt's are good. I could push 1200* and beyond easily (I let off the gas at 1200) many times during the day. I could wash my truck and the stack tips would be covered with soot in only 500 miles. Now it still does it but takes about 5000 miles to look as sooty as it did when stock. If you can't afford the turbo now at least try the 6NZ 2300rpm brakesaver flash and block the wastegate off on the stock turbo when you do. I would have been happy with that alone but my stock turbo was shot it had to be replaced. Haney told me tweaking trim codes would give about 40 more hp but advised me in the interest of better mpg's to leave them stock so I did. Also wanted to add my oil stays cleaner longer. It would turn black pretty quick with MBN files. Again Haney said it would do that. Flash it 6NZ and put some free flow mufflers or run straights and your soot levels will go down.
  7. Sodapop
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    Thanks for the great replies i will try and get my ecm flashed,alrdy have straight pipes..just put a resonnator on today..Thanks again
  8. Sodapop
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    I put my resistor in the fuel sensor,it pulls alot better..but smokes ,more of a dark haze all the way up the hills..fuel mileage aint that great either for a flat top...no more than 5.5
  9. rollin coal
    13,617
    27,991
    Mar 29, 2008
    TN
    5.5 isnt bad for what you have. At night when idling mine used to haze and pulling hills would do the same painting the trailer sides black. Since upgrading it doesnt put any soot on trailers at all no matter how long i may have one. No hazy idling and no smoke on hills. Your motor will be more efficient and run like a raped ape if you 6nz it.
  10. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    Whats your boost under load? Have you checked your turbo and manifold, it my be running rich if the center manifold is burned out. ( common on MBN )I also suggest this due to you have a 525 hp with a fuel wire and the engine is not derating with excessive boost faults under load.
  11. Sodapop
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    i have a resistor on the fuel wire, exhaust temps get way hotter with it on to, i have to watch it. it will get up to 1100 deg pretty quick and i have to get off the gas.it pulls alot better with it on..manifold psi never goes over 30psi.
