Is there hope ?
Discussion in 'CB Radio Forum' started by dca, Apr 7, 2017.
  1. dca
    dca Road Train Member
    6,834
    11,428
    May 31, 2011
    Earth
    If so, what would you do?
  3. Ridgeline
    22,720
    123,228
    Why do they put classic on things that should just be ...
    what's the problem?
    Blaskowitz and dca Thank this.
  4. dca
    6,834
    11,428
    May 31, 2011
    Earth
    No problem yet, just a question
  5. dca
    6,834
    11,428
    May 31, 2011
    Earth
    I had this in storage, it was hooked up to the factory system, that system no longer works.
  6. Ridgeline
    22,720
    123,228
    Try again ... I have no interpreter for that language.
    AND if you are using a phone, I hate that auto correct is the enemy.
  7. dca
    6,834
    11,428
    May 31, 2011
    Earth
    tried this until I removed it. the radio kept falling out of its cubby hole. I think I can solve that issue.
  8. dca
    6,834
    11,428
    May 31, 2011
    Earth
    my apologies for the alien language, I'll see what I figure out, thanks for the reply !
  9. dca
    6,834
    11,428
    May 31, 2011
    Earth
    If someone were to elaborate on setting up a cobra classic with the optimum performance I wouldn't object.
    no further comments from me
  10. Dirtymartini15x
    Dirtymartini15x Light Load Member
    180
    114
    Oct 18, 2016
    It has little to do with the radio as long as it acts as it should. To preform optimally you will need to mount an antenna with a good ground and decent coax. Then tune the antenna to the lowest possible swr.
    dca Thanks this.
  11. quatto
    quatto Medium Load Member
    588
    980
    Mar 9, 2013
    The Bluest State
    I wouldn't eat with that on my lap.
    I wouldn't use it there because it might be considered distracted driving.
    Don't take pictures with a phone in your mouth.
    Radiation from RF might cause testicular cancer.
    That's all I can think of based on your question. ;-)
