Is this normal?
Discussion in 'Flatbed Trucking Forum' started by RockinChair, Apr 27, 2023.
  1. RockinChair
    RockinChair Road Train Member
    5,352
    14,273
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Last night while I was fueling up at Love's there was a double-drop next to me that was hauling a front-load garbage truck. I noticed that the driver had disconnected the polished rods that come out of the hydraulic cylinders from the forks, arms, and tailgate. After loading the truck and chaining it down, why would the driver take extra time to do all that before reconnecting the trailer and getting on down the road?
    TIA.
  3. PSM379
    PSM379 Heavy Load Member
    945
    3,901
    Apr 19, 2019
    Get the height down.
    D.Tibbitt Thanks this.
  4. RockinChair
    5,352
    14,273
    Feb 19, 2012
    The arms and tailgate were already all the way down.
  5. NH Guy
    NH Guy Medium Load Member
    610
    2,079
    Feb 26, 2023
    Maybe it saves wear on the cylinders?
  6. RockinChair
    5,352
    14,273
    Feb 19, 2012
    Now that makes sense.
  7. gentleroger
    gentleroger Road Train Member
    7,886
    21,556
    Jun 1, 2010
    I would guess to guard against cylinder drift. I wouldn't think it would be a real issue, but if the manufacturer says "do this when in transit", then "this" should be done, whether or not it makes sense (please see "turbo dry spin").
    Or boss man had a driver claim cylinder drift when the driver screwed up loading, so now there is POLICY.
  8. RockinChair
    5,352
    14,273
    Feb 19, 2012
    I'm not familiar with cylinder drift, but this was an older truck so it's very possible the hydraulics wouldn't be in tip-top shape.
    Bean Jr. Thanks this.
  9. gentleroger
    7,886
    21,556
    Jun 1, 2010
    It's when there's a leak inside the cylinder and it allows fluid to pass from once side to the other until pressure is equalized. From my (very limited) understanding it happens more at full extend and things drift down to "rest", and most often when the unit is being manipulated. My farmer friend has a problem with his sprayer booms drifting. To fix it he'd have to tear the whole thing apart, which would probably break more things than it would fix so he just deals with it until the 32% nitrogen rusts it out.
    Bean Jr., beastr123 and RockinChair Thank this.
  10. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    Cylinder drift is really only an issue if you are working against weight or gravity. The cylinders can leak internally and bypass and the cylinder can move. Buy again not against thr laws of physics.
    Hydraulic oil does expand or contract slightly with temperature change but not enough to really move anything much. If the Hydraulic pump was running and you have a leaking control valve it could also make things move that shouldn't
  11. MACK E-6
    49,991
    237,943
    For those of us that pull liftgate trailers cylinder drift is an omnipresent potential threat.
    Bean Jr., Old_n_gray, Oxbow and 2 others Thank this.
