Is this OK?
Discussion in 'Flatbed Trucking Forum' started by Freightlinerbob, Jul 11, 2014.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Just the top pieces.
    They are chained together with a 5/16" chain then two 3/8 going one way and one 3/8 going the other way. Not concerned about staying on the deck so much as them moving forward. Nothing more than one piece sticking out to catch it if it slides forward.
  3. snowwy
    snowwy Road Train Member
    20,611
    13,325
    Jul 6, 2009
    if your worried about it going forward, and hopefully you can do something about it. then do.
    safety trumps danger every time.
    put a chain around the front and one in the back.
    the back chain is to keep it tight in the forward motion. otherwise, without the back. the front will slide backwards and you're chain will always be loose.
    if ANY load stands a chance of shooting through the cab. ALWAYS do something so that it DON'T happen.
    wether it be chains or simply building dunnage on the deck. it's your life at risk if you don't.
  4. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Get a block and strap or chain it in front of the beam. Job done.
    Hauling machinery I get spoiled by being able to pull forwards, backwards and side to side. On normal freight though, it isn't always possible I know.
    Martin
  5. nb629
    nb629 Light Load Member
    213
    245
    Aug 21, 2012
    maybe just put a couple choke straps on it, it can only help
    dannythetrucker Thanks this.
  6. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Thanks for the suggestions. Neither was practical but I looked at it again and found a way to positively block the pieces from moving forward.
    Always helps to have another look at it.
  7. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Looks ok, my only concern with be that thing shooting forward on a hard stop. Can you cross chain the front of that beam to prevent it from coming forward?
    Edit:
    Just read your last post. Good deal. Safety first.
    Hurst
  8. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Looks to me like some of the iron on the side sticks out some. Put the chain there and the beam should not be able to move. Also stay away from metal to metal contact. Try to put a piece of wood between the stuff you are stacking up. I keep various 4X4's long and short,2X4's and even some small plywood squares for that purpose. Metal to metal is slippery,the wood gives it something to bite into and it is nonslip.
  9. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I'd hog-tie front and back. (chain wrapped completely around and tied down to both sides). But I'm sure your blocking solution will be fine as well. One of those things, if you have to ask you already knew it wasn't quite done.
  10. Truck Smarter
    Truck Smarter Bobtail Member
    30
    17
    Jun 26, 2014
    Dallas, Texas
    My Vote even though you have it solved. I am with the hog tie or belly wrap as I was taught to call it. Go in front of and behind those pieces the stick out and come down off the top of the beam each side of the trailer going forward with the back one and backwards with the front one. 4 cinches and it should be pretty hard for it to move anyplace. Of course, it is always easy to see a "better way" from the comfort of this easy chair.
  11. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I'll have to talk to Ed then and see if he can't get you a flat for a couple of weeks. LMAO!!!
    passingthru69 Thanks this.
