Have an air leak coming from the ishift. There are 2 round connectors on the passenger side near the top. They appear to be wire harnesses. Thats where it is leaking from. any insight?
Ishift air leak
Discussion in 'Volvo Forum' started by rhitrucking, Dec 4, 2019.
There is a big air fitting on the opposite side of the tranny near the top.... I would check that guy out, also could be leaking at the clutch control module which is that little bolt on fella (bottom right) in your photo
Could also be leaking out of the air line from the CCM that runs up and over diagonally, also same ballpark area
is my picture not showing up? I know exactly where its leaking. Its not actually the one circled in my pic, its the fitting right next to it. Not sure how it comes off, I dont want to break it. Hopefully its just an oring
Long time ago.
You have repaired the leak?
It can be the gearbox top seals. it was a continuous leak? or intermitent.
