Issues with refrigerators
Discussion in 'Ask An Owner Operator' started by Hayes95, Jun 28, 2021.
  1. Hayes95
    Hayes95 Bobtail Member
    6
    Jun 28, 2021
    Can someone explained to me what could be the problem with going through 2 fridges within the last year.I’m using a 3000 watt inverter to run only the fridge?
    Jarhed1964 Thanks this.
  3. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,194
    Aug 26, 2014
    LLMF
    If it's a cheap inverter that could be your problem. You need to be running a pure sign wave. And you don't need anywhere near 3000W just for a fridge.
    More info about your electrical system is needed for more help.
  4. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Don't know what kind you have, but if its not made for a truck that maybe the problem. As it needs to be able to handle bumps and vibration.
    Jarhed1964, skallagrime and slow.rider Thank this.
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Household or dorm fridges won’t handle the bumping and bouncing. Compressor not designed for it. Also more than likely
    Every time you start truck it probably surges power
    Jarhed1964, TallJoe and slow.rider Thank this.
  6. Hayes95
    6
    Jun 28, 2021
    I’m using a PowerDrive inverter.So what kind of fridge do I need to purchase.The kind I have now is a Hisense fridge from Lowe’s.
  7. Hayes95
    6
    Jun 28, 2021
    What kind I do about the power surge when I start truck?
  8. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Need a fridge that can handle a truck environment. I have my fridge that came with trucks and they last a decade or better. Just have to research and get a pure sine wave inverter and use a good surge protector.
    Jarhed1964 and slow.rider Thank this.
  9. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    You could try mounting fridge on some kind of isolator to absorb some shock and vibration.
  10. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    There is two problems what can kill fridge.
    1. Power interruption.
    Fridge compressor motor is only 60 watt asynchronous motor. It's utilize starter devise to start spinning. If fridge compressor was pumping and power was interrupted due to engine start or other reason motor can not start spinning again because high side of the fridge is under pressure. As a result starting devise or winding will be fried.
    To avoid it you can unplug your fridge before engine start, keep battery fresh and connections clean.
    Or install delay relay to power fridge after power interruption. In few minutes pressure will go down and fridge can start as usual.
    2. Vibration.
    Most drivers just put fridge on the floor mat and strap it down with something. This is wrong way.
    Cut 3/4 inch plywood base for the fridge and bolt it to the plywood.
    Drill 4 holes in plywood and attach plywood board to the cab floor with bolts with spacers protruding out of floor mat. If floor is corrugated cut spacer to fit. Board should not rock in any direction and sit firmly on all 4 points.
    Make a L shape bracket to secure fridge top to the side wall. You can use good HD welcro to attach it to the fridge top.
    5 years and no problem.
    PS. Some cheap Walmart fridges will stop working for whatever reason.
    Jarhed1964 and TallJoe Thank this.
