ISX Cummins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Halfdollar, Nov 7, 2018.
  1. Halfdollar
    Halfdollar Bobtail Member
    21
    8
    Jul 16, 2018
    Ok so I got this 07 Cummins ISX, I deleted the egr and turned a little power up. I’m running 7 inch miter cuts off stock exhaust. How can I get my jake louder? Pulling she sounds good but jake is quite. Tia
    D.Tibbitt Thanks this.
  3. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    Right where the exhaust turns up to head to the stack you'll want to put a 90 on it and cut a hole through the back of your cab. Add a six inch piece to that and make sure you seal the area between the pipe and the cab hole. You dont want to risk getting any fresh air in. This will make it super loud and not annoy others on the road.
    pup, stwik, D.Tibbitt and 5 others Thank this.
  4. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I nearly laughed out loud at this. Too bad all the 6 and 8" diameter stack idiots won't follow this same advice.
  5. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    If you want louder remove the muffler.
    Or just install a N14.
  6. D.Tibbitt
    156,763
    Theres a switch on the tall shifters to turn up the volume on ur jakes, theres also a button that deploys the shark teeth on the front grill for when ya really wanna be cool, just make sure ur shifter goes up to the ceiling , the short versions are not equipped with these features
    Intothesunset Thanks this.
  7. Halfdollar
    21
    8
    Jul 16, 2018
    Ok sorry I wasn’t clear. This question is for truck drivers, not the Volvo drivers with flip flops and shorts
    bowhunter67 Thanks this.
  8. Halfdollar
    21
    8
    Jul 16, 2018
    That’s the problem with the trucking industry today. Too many smart ### steering wheel holders that think they know everything. I’d love to see how a real trucker in the 80’s would wipe the smirk offf of your face. God forbid anyone ask a question, and a question that you all don’t seem to know the answers too.
    nitetride379x and bowhunter67 Thank this.
  9. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    You need to pull that garbage can size muffler out and go strait up from the y pipe.
  10. Halfdollar
    21
    8
    Jul 16, 2018
    I have a set of 5 in straights and a set of 8 in straights. Witch do you think
  11. bowhunter67
    283
    549
    May 28, 2016
    rush city mn
    I put 7 inch on my w9 not alot of room for 8 inch and I have a 2006 870 cummins and it rumbles nice.
