Anybody had any problems with the egr valve after egr cooler replacement ? Had my cooler replaced under warranty,ran good for a week,now runs rough again.Just wondering if the mechanics at Kenworth,are telling me fairy tales ?![]()
ISX egr systems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ggswede, Aug 6, 2012.
I would delete it if possible. No worries then. I know my Detroit ran like crap even after they replaced the whole egr system. I say chunk it if you can.
Ethan -
What does a cooler have to do with it running rough?
The EGR valves on the ISX made prior to the '07 model engine can fail at any time, so replacing the cooler may have nothing to do with it. But you might want to check that they got the wiring back on it, or that it has not rubbed and shorted out.
We are going through egr valves like crazy. Our 2015 peterbuilts sit and run for weeks with the pto on. Any help?
I would suspect excess heat in the engine bay is taking them out since it isn't getting any air flow that it normally would while on the highway. Try to leave the hoods open as much as possible if you are running extended PTO hours.
